Fuel leak from tank area!
Old Mar 5, 2008 | 06:40 PM
alscrx's Avatar
Default Fuel leak from tank area!
Today i filled up my tank topping it off. I drove about 20 minutes away and parked... I sat in the car for about 10 minutes and when i got out i noticed a little stream of fluid. It looked black and when i touched it, it was black and looked like oil but DEF smelled like fuel.
I looked under and can see fuel dripping down very slowly though. Any ideas or experience wanted please. I rather order some parts now than drop the tank twice. I am gonna look under tomorro if weather permits to see the general area of leak......
Any ideas whats leaking under there?
Old Mar 5, 2008 | 06:43 PM
EFstyle's Avatar
Default Re: Fuel leak from tank area! (alscrx)
Driver or Passenger side of the tank?
Old Mar 5, 2008 | 08:30 PM
alscrx's Avatar
Default Re: Fuel leak from tank area! (EFstyle)
Looks to be from the driver side...but not sure if its just dripping to that end or if its actually leaking from the driver side.
Old Mar 6, 2008 | 03:38 AM
Hondaisok's Avatar
Could be from the return line. There is a junction with a plastic cover by the rear wheel. I had a leak there once and replaced the line with fuel line.
Old Mar 6, 2008 | 03:58 AM
~sp33~'s Avatar
EFB055
A friends DA integra dropped a small puddle of gas after topping it right up, there was a hole in the tube that transfers petrol from the hole to the tank.
Old Mar 6, 2008 | 05:25 AM
biggee's Avatar
I have changed a couple filler necks that were leaking right at the tank.
Old Mar 6, 2008 | 05:52 AM
alscrx's Avatar
Default Re: (biggee)
Hopefully i can look today, I won't have time to drop the tank till saturday. Looks like it could be a few things, So before i buy anything i guess i'll drop the tank and take a look. Hopefully the tank will be almost empty by then.
I am only getting about 200 miles per full tank! Motor is a b16 with J1 tranny and PW0
Old Mar 6, 2008 | 05:55 AM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggee &raquo;</TD></TR><TR><TD CLASS="quote">I have changed a couple filler necks that were leaking right at the tank.</TD></TR></TABLE>
Did you change the actual filler neck or a gasket that seals it?
That neck is like 100 bucks from honda. Sure hope its not the Neck or Tank itself. Awhile back i did smell fuel inside the car after i filled the tank up. I don't smell any fuel inside now at all. So not sure why it went away on its own
Old Mar 6, 2008 | 07:35 AM
alscrx's Avatar
Default Re: (alscrx)
So i noticed the fuel pressure gauge when i turned the car off was at like 30psi.
A few hours later while still parked it read 0PSI.
I wanted to know if the fuel system is supposed to drop to 0PSI after the car has been sitting for awhile or is it supposed to retain pressure?
Old Mar 6, 2008 | 12:46 PM
93civiceg6's Avatar
i have had issues in the past with the filler neck it was rusted rotten so try that
Old Mar 6, 2008 | 03:33 PM
biggee's Avatar
running I believe mine sits around the 40psi mark and it drops a bit after the car is shut off. My fuel pressure will drop to zero, but I think it takes a day or so before it does that.
Old Jul 24, 2020 | 07:24 AM
Rennton#60's Avatar
I have an 89 honda crx have noticed fuel leaking from front of gas tank and on drivers side by the fuel neck filler and overflow line. I replaced all the hoses on the drivers side of the tank. I ran it for around 10 mins to check for leaks. I then topped it off and took it for a test drive. Came back same problem. When I had dropped the tank I checked the fuel sending unit and fuel pump housing both looked good no fuel leakage was present in the area. So Im at a dilemma as to where the fuel can be coming from.
Old Jul 24, 2020 | 10:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
How about the rubber hose that connects the tank to the filler neck?
Old Jul 24, 2020 | 05:03 PM
Rennton#60's Avatar
yes I checked that and even replaced it with a new one. Drove the car again today no change. still leaking from the front of the tank.
tolowhb
16
Jul 24, 2020 07:37 AM
vulch
May 8, 2015 08:09 AM
g2turbo
Aug 21, 2013 09:08 AM
SlowazzGSR
Honda Motorcycles
Apr 3, 2010 06:50 PM
HamiltonRex
10
Feb 7, 2006 05:46 PM
