Lots of SHIET for sale
PRICES UPDATED AND OBO
Here is a list of parts I have for sale:
NEW K-tuned AC & PS removal kit ----$160
Tial 44mm WG... purple and silver---- $290 each
NEW OBX 50mm BOV silver------------$150
NEW Wiseco 86mm and Eagle rod combo-$730
NEW K- series Wavetrac LSD---------------------$900
NEW RBC intake------------------------$160
type S throttle body with sensors--------$160
Civic SI K series 5 speed trans------------$600
30"x12"x3" intercooler, new only mounted--$130
Type S head with all valvetrain but not installed- $700
Sparkks racing conversion harness--------------$250
K20a2 crank GOOD-------------------------------$250
Type R cams------------------------------------$275
Type S alternator------------------------------$150
03 k20a2 engine harness-----------------------$250
NEW Competition clutch stage 2---------------$350
NEW competition clutch stage 4---------------$350
K20 flywheel------------------------------------$50
Aeromotive FPR----------------------------------------$120 shipped
BOSCH 044 fuel pump, brand new never used only installed-$250 shipped
resistor box with pigtail $30
04 Type S fuse box- $50 shipped
Integra lower tranny mount, $30
ALL SENSORS OFF obd2 ls motor.... make offer for each, iac, etc... have them all...
OBD2 Ls intake $30
ALL SWAP MOUNTS, $100 for set, includes, ac bracket, lower tranny mount, driver side mount, tranny mount, rear t-bracket, and rear mount.
OBD2 ls valve cover
OBD1 LS valve cover, $20
Integra rear t-bracket, $30
stock b-series fuel rail, $20
EG hatch side skirts, $25
LS obd1 engine harness, $75
B-series flywheel $20
B-series shift linkage, $40
B-series half shaft, $40
Integra driver side mount, $20
B series speed sensor, $30
K20a2 stock header, $10
Bseries stock clutch line, goes from firewall to tranny $15
EK condensor $10
K20a2 power steering pump $40
LEGIT LS longblock. Needs rebuild. $200
obd2 b-series manual starter $40
obd2 b-series power steering pump $30
obd2 b-series alternator $40
obd2 ls ecu $75
part of DC2 that is under the tail lights that goes across back of car above bumper, perfecto condition, $75
92-95 hatch rear bumper, black OEM, 6 out of 10 condition on paint, $25
Up for sale are 2 collectors.
collector is a T3 divided. It is twin scroll and has flange welded. Bought these pieces from Straight Line Specialties for $80
Willing to let these go for $75 shipped.
EBC Rotors NEW IN BOX drilled/slotted zinc anodized, found here for $123.11, the cheapest place on the net. Sold in pairs. Perfect for upgrading your stock brake rotors. $90 OBO
Will fit:
Honda Civic 1.5 DX Coupe (1993-1995) Front Kit (L/R)
Honda Civic 1.6 DX Coupe (1996-2001) Front Kit (L/R)
Honda Civic 1.6 HX Coupe (1996-2001) Front Kit (L/R)
Honda Civic 1.5 Hatchback (1990-1995) Front Kit (L/R)
Honda Civic 1.5 Sedan (1990-1995) Front Kit (L/R)
Honda Civic 1.5 Wagon 2wd (1990-1991) Front Kit (L/R)
Honda Civic 1.6 Hatchback (1990-2000) Front Kit (L/R)
Honda Civic 1.6 Sedan (1994-2001) Front Kit (L/R)
Honda CRX 1.5 DX CRX (1990-1991) Front Kit (L/R)
Honda Del Sol 1.5 (1993-1997) Front Kit (L/R)
Honda Del Sol 1.6 (1993-1997) Front Kit (L/R)
LS Vtec oil line, NO ADAPTER, $40
Shift linkage, 94-01 integra b-series $40
94-01 integra
LS gauge cluster, manual with 130k. $50
94-01 Integra Glove box $20
94-01 Integra Gauge cluster bezel $10
94-01 Integra Dash kicker panel under steering column $10
Modified by HickamHatch at 8:26 PM 9/30/2008
OBD2 Ls intake $30
OBD2 ls valve cover
EK condensor $10
obd2 ls ecu $75
Will fit:
94-01 integra
