arp gsr bolts question
Old Mar 5, 2008 | 06:17 PM
boss123's Avatar
Default arp gsr bolts question
hi i have a set of arp bolts for gsr motor, but i was wondering
if i can use them on a b16 motor with a itr head.
help
Old Mar 6, 2008 | 02:31 PM
vshavoc's Avatar
Default Re: arp gsr bolts question (boss123)
Should work. I'm using arp head bolts on a gsr block with a type r head. Get on the arp website and check the part numbers and see if they are the same for all b series engines.
Old Mar 6, 2008 | 03:31 PM
95 integra's Avatar
Default Re: arp gsr bolts question (vshavoc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vshavoc &raquo;</TD></TR><TR><TD CLASS="quote">Should work. I'm using arp head bolts on a gsr block with a type r head. Get on the arp website and check the part numbers and see if they are the same for all b series engines.</TD></TR></TABLE>
They arent the same. The B16 uses a shorter deck height and thus shorter bolts. Now generally ARPs have enough threads that they will work, however I would get the correct ones for your application being that they do make "long" ones and "short" ones for this specific reason.
Old Mar 7, 2008 | 10:16 AM
vshavoc's Avatar
Default Re: arp gsr bolts question (95 integra)
Good knowledge!!!
phan222001
Sep 4, 2009 05:36 AM
SI_frankenstein
Sep 2, 2009 01:29 PM
loudassVTEC
Apr 27, 2005 04:41 PM
B1Boosted
Feb 27, 2004 09:47 PM
neumonik
Nov 28, 2001 07:55 PM
