Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Water on the floor
Old Mar 5, 2008 | 03:35 PM
rEM2's Avatar
Default Water on the floor
So it rained a lot last night and I get into my car to go to work. My passenger side floor mat is drenched and when I lift it up the carpet is also drenched (as if you took a hose to the car floor for a few minutes).
So I get to work use the shop vac to get out majority of the water. The plastic piece where the wipers are has a little bend up and we took that off. The tech said it could be the water going down it and into the vents in the car falling onto the floor behind the glove box. Yes everything was dry inside, the windshield, windows, headliner only the floor was wet.
Has anyone had this problem? We used a type of sealer but it still got damp later tonight when I just checked it. Help Please!
Old Mar 5, 2008 | 03:41 PM
Nighthawk7thGen's Avatar
Default Re: Water on the floor (rEM2)
I have the same exact problem and i still haven't figured it out yet either....and I've been dealing with the issue since i discovered the problem 6 months ago when I did some weight reduction and tore out the carpeting.
Old Mar 5, 2008 | 03:42 PM
krashoveride's Avatar
are you positive the water in the floor is from the rain?
Old Mar 5, 2008 | 04:04 PM
rEM2's Avatar
Oh yes it is. I have been through car washes many times and this is the first time this has happened. There was water marks on the underside of the glove box because the water was dirty so you can see dirt trails. Where else can the water be from?
Old Mar 5, 2008 | 04:24 PM
hondalove323's Avatar
your weather stripping must be really bad and worn out
Old Mar 5, 2008 | 06:38 PM
Kongo69's Avatar
mine comes in the trunk fills the spare tire space then spills over into the back seats then into the floolr board but that was durig six months of sitting but sometimesheavy breaking will get the back seat.
Old Mar 6, 2008 | 06:15 AM
PnX-R's Avatar
I'm not sure which plastic piece you're talking about. But I can tell it's there for a reason, I'd try replacing that first. If it still leaks, there's still other routes you can take. I usually find this problem on the old crv's. I ended up building a custom shield that diverts water away from the air inlet of the HVAC system.
Old Mar 6, 2008 | 07:12 AM
_em2_'s Avatar
Default Re: Water on the floor (PnX-R)
happend to me too mines was the weather stripping for the front winshild i put silcone or watever on the plastic peice on the bottom that covers the windshield by the wipers
Old Mar 6, 2008 | 01:02 PM
MrXclusivE's Avatar
Default Re: (Kongo69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kongo69 &raquo;</TD></TR><TR><TD CLASS="quote">mine comes in the trunk fills the spare tire space then spills over into the back seats then into the floolr board but that was durig six months of sitting but sometimesheavy breaking will get the back seat.</TD></TR></TABLE>
LOL!
Old Mar 7, 2008 | 09:49 AM
GriFFIthS's Avatar
Default Re: Water on the floor (_em2_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _em2_ &raquo;</TD></TR><TR><TD CLASS="quote">happend to me too mines was the weather stripping for the front winshild i put silcone or watever on the plastic peice on the bottom that covers the windshield by the wipers</TD></TR></TABLE>
i had the same issue when i bought mine, i just picked up some Urathane and sealed it up, never had a drop sence.
Old Mar 7, 2008 | 09:58 AM
oddmut's Avatar
Default Re: Water on the floor (GriFFIthS)
i'm lucky don't have it on the inside, but i gotta spray the trunk from underneath to find my water leaks. hehe.
Old Mar 7, 2008 | 09:40 PM
rEM2's Avatar
So it is pouring out tonight! I cannot wait to see how flooded my car will be in the morning, I need to fix it quick!
CooperNOLA
Honda CR-V & Element
May 6, 2017 09:15 AM
dlenoxx
Dec 2, 2010 12:05 PM
oldskoolDA6
Oct 31, 2007 01:51 PM
acuraocd
Feb 2, 2006 05:12 AM
Arvid
May 11, 2003 08:35 AM
