Are Tuner springs and Retainers good for Pro Cams?
Old Mar 5, 2008 | 02:59 PM
12sec14's Avatar
Default Are Tuner springs and Retainers good for Pro Cams?
I have a set of Titanium Springs and Retainers. I know they are Skunk2.
However, I dont know if they are Tuner Series or Pro Series!
I Also Have some Pro 2 Cams.
Will it be safe to run my cams with the springs and Retainers?
The last thing I want to do is drop a valve after rebuilding the bottom end!
The Rev limit will be around 9k but will not see that very often as its going to be driven by my Gal.
Paul.
Old Mar 5, 2008 | 03:37 PM
98vtec's Avatar
moderator emeritus
Default Re: Are Tuner springs and Retainers good for Pro Cams? (12sec14)
if its the last thing you want, then i would recommend the Pro series valvetrain as the tuner and pro series cams are two different can of worms.
Old Mar 5, 2008 | 03:45 PM
mx621's Avatar
Default Re: Are Tuner springs and Retainers good for Pro Cams? (98vtec)
i have tuner series springs/ti retainers with sk2 forged valves on pro 2's, no issues, rev cut @ 9000rpm's. setup has around 4k miles on it so far with ALOT of abuse and track time. my .02 cents
Old Mar 5, 2008 | 04:59 PM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">if its the last thing you want, then i would recommend the Pro series valvetrain as the tuner and pro series cams are two different can of worms.</TD></TR></TABLE>
I 100% agree with this statement.
Pro2 and Pro series valvetrain.
Old Mar 5, 2008 | 09:56 PM
cartune network's Avatar
Default Re: Are Tuner springs and Retainers good for Pro Cams? (mx621)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx621 &raquo;</TD></TR><TR><TD CLASS="quote">i have tuner series springs/ti retainers with sk2 forged valves on pro 2's, no issues, rev cut @ 9000rpm's. setup has around 4k miles on it so far with ALOT of abuse and track time. my .02 cents</TD></TR></TABLE>
and just by doing so you have voided any warranty that skunk2 may have offered.
pro series cams are a different beast compared to the tuner series cams.
use the according valvetrain for the cams. no need to skimp out on springs.
Old Mar 6, 2008 | 05:51 AM
itgsr98's Avatar
Default Re: Are Tuner springs and Retainers good for Pro Cams? (cartune network)
Read!
http://www.skunk2.com/Engine/i...SPPRO
Designed for pro series cams.
Verify the part number of the springs if the are tuner series, sell them and spend the extra 100.00 or so and get the pro series springs. It will be a lot cheaper than rebuilding you motor if you drop a valve.
Old Mar 6, 2008 | 08:17 AM
12sec14's Avatar
Default Re: Are Tuner springs and Retainers good for Pro Cams? (itgsr98)
Ok I get the point, Its not just the Revs! Its also the amount of lift given by the Cam Shaft.
Thanks for the Advice Guys.
Old Mar 6, 2008 | 08:26 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12sec14 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I get the point, Its not just the Revs! Its also the amount of lift given by the Cam Shaft.
Thanks for the Advice Guys. </TD></TR></TABLE>
lift, ramp speeds, closing speeds, spring seat pressure...etc
Old Mar 6, 2008 | 01:34 PM
kpowerdhatch's Avatar
a quick and easy way to determine which is which would be weighing them also. Skunk has the weights on their site.
Old Mar 6, 2008 | 02:43 PM
12sec14's Avatar
Default Re: (kpowerdhatch)
thats a damn good idea! Well done mate, thanks.
Old Mar 6, 2008 | 02:57 PM
Import RP's Avatar
Default Re: (12sec14)
Skunk2 has told us the Tuner Springs are okay for the Pro 1 cams, but for the Pro 2 and 3, you'll want Pro Series springs for sure.
Old Mar 6, 2008 | 05:52 PM
Default Re: (Import RP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import RP &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 has told us the Tuner Springs are okay for the Pro 1 cams, but for the Pro 2 and 3, you'll want Pro Series springs for sure. </TD></TR></TABLE>
Yea I was told that also.
Old Mar 7, 2008 | 05:25 AM
jdm_ef9's Avatar
I know several people that have used skunk2's "tuner" series as well as other companies valvetrain with PRO2 and PRO3 cams.
Old Mar 7, 2008 | 12:43 PM
Default Re: (jdm_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">I know several people that have used skunk2's "tuner" series as well as other companies valvetrain with PRO2 and PRO3 cams. </TD></TR></TABLE>
They may work but if Skunk recommends Pro springs for Pro 2 and Pro 3, why not run them?
Old Mar 7, 2008 | 01:31 PM
jdm_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpowerdhatch &raquo;</TD></TR><TR><TD CLASS="quote">
They may work but if Skunk recommends Pro springs for Pro 2 and Pro 3, why not run them?</TD></TR></TABLE>
Many reasons.... biggest one being $$$.
Old Mar 7, 2008 | 01:33 PM
98vtec's Avatar
moderator emeritus
Many reasons.... biggest one being $$$.</TD></TR></TABLE>
good luck with breaking something and trying to make a warranty claim.
Old Mar 7, 2008 | 01:45 PM
.I.Need.Money.'s Avatar
That must make it okay then.
Old Mar 7, 2008 | 01:46 PM
98vtec's Avatar
moderator emeritus
Default Re: (93EGB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
That must make it okay then.</TD></TR></TABLE>
sarcasm at its finest!!
Old Mar 7, 2008 | 02:08 PM
jdm_ef9's Avatar
Default Re: (98vtec)
gotta love it.... i never stated that it would "make it okay" or that it would be covered under warranty. all i stated is that i know many people that have successfully used "other" springs with PRO cams.
Old Mar 7, 2008 | 02:14 PM
DonF's Avatar
So, you or they are going to cover the warranty if there is a problem?
Old Mar 8, 2008 | 11:13 AM
d15Beta's Avatar
lol exactly... just cuz some people do it.. and they do ok.. doesnt mean its the right thing to do... specially not the right thing to say on a forum where 99% of the noob readers follow the hearsay book... just too dangerous, we'll see more and more of " skunk2 broke, my motor blew up" plea
Old Mar 8, 2008 | 01:49 PM
ilikehonda's Avatar
skunk2 told me that if i was going to run pro2 cams it would be in my best interest to buy pro series valvetrain, but pro1's will work fine on tuner series valve train
Old Mar 8, 2008 | 03:37 PM
mx621's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">
use the according valvetrain for the cams. no need to skimp out on springs.</TD></TR></TABLE>
thanks for the concern, but if i was lookin for a warranty i wouldnt drive an 8 year old honda, non the less modify it. maybe when i build the 2.0L here soon ill swap the springs out? i know two other people running pro 2's down my way, non of them using pro series springs, no issues... one using supertech, other ferrera springs.
Modified by mx621 at 4:59 PM 3/8/2008
Old Mar 8, 2008 | 03:45 PM
12sec14's Avatar
I dont have a warrenty so if I was to use Tuner Springs then drop a valve because of it I would be pretty unhappy.
My build is being done on a budget so its taken awhile to get all my parts. Im not going to take short cuts though as its gunna cost more in the long run!
ITRBOY1433
Sep 21, 2008 10:00 AM
wesley_925
Jun 2, 2008 06:14 AM
