d16y7 motor with a 91 si tranny, clutch difference?
Old Mar 5, 2008 | 02:57 PM
pinks11's Avatar
Default d16y7 motor with a 91 si tranny, clutch difference?
Im going to replace my clutch today, and I wanted to see if the clutch I bought was going to fit. I got a 6 puck clutch from clutchnet for the si tranny. But my main concern is that I'm not too sure if it's actually an si tranny. I was told from my friend that I bought the car from that the transmission was si. It sure does feel like it, but is there any way I can tell? Any codes? Teeth on the spline?
I know the difference between a zc and si tranny, but i just want to clarify if theres any info I can get before I start running into problems.
Modified by pinks11 at 4:15 PM 3/5/2008
Old Mar 5, 2008 | 05:24 PM
whiteknightef's Avatar
Default Re: d16y7 motor with a 91 si tranny, clutch difference? (pinks11)
This is how you tell:
http://i247.photobucket.com/al...1.jpg
or
Are you using a Y7 engine?
Old Mar 5, 2008 | 09:05 PM
pinks11's Avatar
Default Re: d16y7 motor with a 91 si tranny, clutch difference? (whiteknightef)
yes i am, that diagram helped in a sense, never seen it before.
Old Mar 6, 2008 | 03:03 AM
90crxdriver's Avatar
Default Re: (whiteknightef)
Wow that helped alot now I can go find out what trans I'm buying instead of installing it and seeing how short the ratios are. THANKS
Old Mar 13, 2008 | 08:53 PM
pinks11's Avatar
Default Re: (whiteknightef) (90crxdriver)
i just got a tranny.. I bought it thinking that it was an si but now that i think abt it, it might be an hf... i think that because the gears are long as hell...
EFAGE
Jun 2, 2013 05:53 PM
EFstyle
Jul 20, 2007 01:16 PM
yellowcrx13
May 15, 2004 07:12 PM
