Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
►►► SKUNK2 CAMBER KITS, COILOVERS, COMBO'S | ROCK SOLID LOW PRICING | FREE SHIPP
Old Mar 5, 2008 | 02:50 PM
THMotorsports's Avatar
Default ►►► SKUNK2 CAMBER KITS, COILOVERS, COMBO'S | ROCK SOLID LOW PRICING | FREE SHIPP
STILL GOING STRONG IN 2012
Pro S II Coilovers
You asked for it, you got it. Skunk2’s completely redesigned, fully adjustable Pro-S II Coilovers have arrived. Similar to Skunk2’s industry-leading Pro-C Coilovers, Pro-S II Coilovers now feature double-adjustable ride height and a state-of-the-art mono-tube design. Thanks to threaded shock bodies, Pro-S II Coilovers now offer height adjustments independent of spring preload, which results in significant ride-height changes without sacrificing shock travel or ride comfort. Quick and precise ride-height adjustments can now be made for dialing in corner balancing as well as for improved handling, responsiveness, and overall balance. Skunk2’s track- and street-tested Pro-S II shock valving offers the perfect balance between daily driving and track performance and its all-new, shortened shock bodies and reduced shaft strokes help maintain adequate suspension travel on lowered vehicles for improved performance without sacrificing comfort.
Pro-S II Applications
541-05-5715 1988-91 CIVIC (ALL MODELS) PM FOR H-T PRICE!
541-05-4720 1992-95 CIVIC (ALL MODELS) *Version 2* PM FOR H-T PRICE!
541-05-5730 02-04 RSX (ALL MODELS) PM FOR H-T PRICE!
541-05-5740 02-05 CIVIC SI PM FOR H-T PRICE!
541-05-4725 1996-00 CIVIC (ALL MODELS) *Version 2* PM FOR H-T PRICE!
541-05-4717 1990-93 ACURA INTEGRA (ALL MODELS) *Version 2* PM FOR H-T PRICE!
541-05-5700 PRO SERIES UPPER MOUNT 88-00 CIVIC/CRX/DEL SOL; 90-01 INTEGRA PM FOR H-T PRICE!
541-05-5880 2004-2008 ACURA TSX PM FOR H-T PRICE!
541-05-4750 2006+ CIVIC (ALL MODELS) *Version 2* PM FOR H-T PRICE!
541-05-4715 188-91 CIVIC (ALL MODELS) *Version 2* PM FOR H-T PRICE!
Pro C Coilovers
Skunk2 Pro-Series high performance coilovers are based on over a decade of racing and suspension tuning experience. The advanced technology we have used in numerous road racing and drag racing championships is now being applied to our new line of Pro-Series coilover suspensions. Skunk2’s track and street tested valving offers the perfect balance for the daily drive or for spirited performance driving. Pro-Series coilovers feature shortened shock bodies and shortened shaft strokes so suspension travel can be maintained on lowered vehicles for improved performance and comfort. With Skunk2 coilovers, enthusiasts can quickly and precisely set ride heights and corner weights to improve the vehicle’s handling response, cornering ability, stability, and balance. Our full coilover suspension is offered in our nonadjustable dual-tube PRO-S design, or our PRO-C adjustable mono-tube design. Skunk2 coilovers include hard anodized CNC-machined forged 6061-T6 spring perches and Skunk2 CNC-wound racing springs made from SAE9254V spring steel.
Pro-C Applications
541-05-6720 Integra (ALL) 1994-01Civic/Del Sol (ALL) 1992-95 PM FOR H-T PRICE!
541-05-6725 Civic (ALL) 1996-00 PM FOR H-T PRICE!
541-05-6715 Civic/CRX 88-91 PM FOR H-T PRICE!
541-05-6750 '06 - Honda Civic Pro-C Coilover PM FOR H-T PRICE!
541-05-6990 '06 - Honda Fit Pro-C Coilover PM FOR H-T PRICE!
541-06-6300 2003 - 2006 Mitsubishi Evolution VII - XI PM FOR H-T PRICE!
541-05-6400 S2000 Pro-C Coilover PM FOR H-T PRICE!
Pro-Series Front Camber Kits: Pro-Series Plus & Tuner also available
Pro Series
This is what we recommend as a good entry-level camber kit. The Pro-Series camber kit features the same one-piece forged Pro-Series balljoint used in the Pro-Plus kit, but instead of polyurethane bushings, the Pro uses standard high quality rubber bushings. Though the Pro kit is slightly more expensive than the Tuner series, the benefits and convenience offered by the Pro-Series ball joint provide excellent value.
Applications
516-05-5670 1992-95 CIVIC /DEL SOL(EG/ALL) PM FOR H-T PRICE!
516-05-5680 1996-00 CIVIC/DEL SOL(EK/ALL) PM FOR H-T PRICE!
916-05-5670 PRO SRIES CAMBER KIT BALL JOINT & TOP PLATE PM FOR H-T PRICE!
516-05-0004 Pro Series Front Camber Kit: 03-08 Acura TSX PM FOR H-T PRICE!
516-05-5660 Pro Series Front Camber Kit: 88-91 EF Honda Civic PM FOR H-T PRICE!
516-05-5650 Pro Series Front Camber Kit: 90-93 DA Integra PM FOR H-T PRICE!
Pro-Series Rear Camber Kits:
The design of Skunk2 Rear Camber Kits is based on camber kits that we have been using in our race cars for many years. Skunk2 Rear Camber Kits are a must if you want to fine tune your rear suspension. With the ability to adjust positive and negative camber, you can reduce tire wear and significantly improve your vehicle’s handling. Made from forged alloy steel and aircraft quality AL7075 aluminum, Skunk2 Rear Camber Kits feature low deflection polyurethane bushings. The bushings act as a bearing allowing your camber kit to pivot smoothly without the harsh side effects of using actual spherical bearings. Unlike the steel and rubber bushings that are found on low quality rear camber kits, these will not tear or break free. The Skunk2 Rear Camber Kit is the perfect choice for street and race applications, and works even better when used in conjunction with Skunk2 Rear Lower Arms, Arm Bars, Strut Bars, and Front Camber Kits.
Applications
516-05-0500 1988-00 CIVIC, CRX, DEL SOL(ALL); 1990-01 INTEGRA (ALL) PM FOR H-T PRICE!
516-05-0510 2002-05 CIVIC Si H/B; 01-05 Coupe/4DR; 05-06 RSX TypeS & BASE PM FOR H-T PRICE!
516-05-0525 2006 CIVIC (ALL) GOLD ANODIZED PM FOR H-T PRICE!
516-05-0520 2006 CIVIC (ALL) HARD ANODIZED PM FOR H-T PRICE!
How to order?: Call us at the number below
Call 1-800-959-0145 toll free and mention the sale
**Master Card, Visa, Discover, AMEX** OR PM US!!!!!!!
EMAIL: Lpawlik@thmotorsports.com
WE ALSO USE AIM: Lpawlik@thmotorsports.com
Old Mar 6, 2008 | 06:33 AM
Default Re: ►►► SKUNK2 CAMBER KITS, COILOVERS, COMBO'S | ROCK SOLID LOW PRICING | FREE S
Bump
Old Mar 6, 2008 | 12:16 PM
J.P. 4rm The dPk*'s Avatar
Old Mar 7, 2008 | 08:19 AM
Thanks for the hands up
Old Mar 7, 2008 | 03:57 PM
allshownogo's Avatar
gimme a price on front and rear 95 civic 2 dr dx
Old Mar 7, 2008 | 05:02 PM
killerbee ek9's Avatar
bump!!!
Old Mar 10, 2008 | 08:16 AM
Bump it up
Old Mar 13, 2008 | 08:41 AM
Default Re: (THMotorsports)
PM's replied
Old Mar 17, 2008 | 09:48 AM
bump
Old Mar 24, 2008 | 09:17 AM
bmoua's Avatar
pmed...LMK bro
Old Mar 25, 2008 | 07:45 AM
Default Re: (bmoua)
Replied on the cheap deals
Old Mar 31, 2008 | 09:54 AM
bump
Old Apr 14, 2008 | 08:29 AM
Thank you for all of the orders
Old Apr 15, 2008 | 07:44 AM
Pm's replied on camber kits
Old Apr 22, 2008 | 07:46 AM
Thanks for the orders
Old Apr 28, 2008 | 06:44 AM
Thanks . All orders shipped
Old Apr 29, 2008 | 08:33 AM
bumpo
Old May 2, 2008 | 08:45 AM
bump and in stock
Old May 2, 2008 | 10:33 AM
jdmeeeeeeeeg's Avatar
Old May 5, 2008 | 07:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeeeeeeeeg &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Thank you !!!
Old May 8, 2008 | 08:38 AM
bump it up
Old May 9, 2008 | 07:20 AM
Thanks for all the orders
Old May 15, 2008 | 07:30 AM
Thanks everyone . Shipping today on the muffler
Old May 15, 2008 | 06:35 PM
fasthatchb18c1's Avatar
Made an order for a front and rear myself, nice prices.
I ordered the password jdm 3 point front and 4 point rear strut bars as well, just wondering if you have them in stock? If not how long should it take?
thanks
Old May 16, 2008 | 06:38 AM
Default Re: (fasthatchb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Made an order for a front and rear myself, nice prices.
thanks</TD></TR></TABLE>
We will let you know ETA times on your invoice and or call you. We like to keep our customer updated
