mud guards not fitting
Old Mar 5, 2008 | 02:31 PM
westcoast1994's Avatar
Default mud guards not fitting
i tried installing mud guards on my 95 civic hatch back. the front went on fine with the exception of a fender being slightly bent. when it came time for the rears... well the holes in the bumper and the hole on the frame are about a half inch above the holes in the mud guard itself. i hope i explained that enough.
i was wondering if maybe i have coupe mud guards. or if the jdm civic rear bumper is different. or difference between the years of the 92-95's. it fits the countours of the bumper perfect, its just that the mounting holes don't match.
i did a brief search and only found magazine adds where someone had mud guards or for sale threads. just hoping someone has encountered this before and can guide me through thanks.
Old Mar 5, 2008 | 03:04 PM
Default Re: mud guards not fitting (westcoast1994)
c'mon help me out. i know i don't have a question on whether to drop a k or a b series into my hatch. as those get a lot of attention. but give me a break my mud guards ain't fiting.
Old Mar 5, 2008 | 03:52 PM
x0!'s Avatar
x0!
mine fit perfect. just use some self tapping screws and put new holes?
Old Mar 5, 2008 | 03:59 PM
jerryegk24's Avatar
the rear bumper should have two rubber attach on each side. remove the rubber inside the rear bumper than put your mud splash guard on than the rubber after.
Old Mar 5, 2008 | 04:09 PM
Default Re: mud guards not fitting (jerryegk24)
hm... rubber inside the rear bumper. didn't see any i'll take a look tomorow. i'm pretty sure i didn't see anything other then the actual bumper.
Old Mar 5, 2008 | 04:18 PM
Default Re: (x0!)
my friend mentioned just using the self tapping screws. i would feel more comfortable using these bolts i got. philips with a washer and bolt. i was worrying about the part that attaches to the frame. i don't want the mud guards flapping in the wind. and i would much rather prefer using the oem mounting points.
Old Mar 5, 2008 | 04:40 PM
ke98248's Avatar
Default Re: (westcoast1994)
Using a few screws to attach the mud guards to the car shouldn't be a problem.. They should hold quite well..
scootr
Jan 23, 2017 10:47 PM
batey804
May 28, 2010 01:44 PM
prelude182
Mar 12, 2010 12:51 PM
InTheLBC20
Jan 19, 2010 08:27 AM
VTECVillain
Jul 7, 2002 11:11 AM
