94 GSR Engine Start
Old Mar 5, 2008 | 12:43 PM
datoad's Avatar
Default 94 GSR Engine Start
Hey guys, I have a 94 GSR and I have a problem when I start my car sometimes. sometimes when I turn the key to start the car, there will be a high pitch squeeling sound but the engine doesn't crank to start. This doesn't happen often but I was wondering what is causing this and also if there is something wrong with my engine?
Thanks in advance!
Old Mar 5, 2008 | 03:02 PM
vshavoc's Avatar
Default Re: 94 GSR Engine Start (datoad)
It's your starter not engaging.
Old Mar 5, 2008 | 06:16 PM
datoad's Avatar
Default Re: 94 GSR Engine Start (vshavoc)
I have asked around and have also heard people say it might also be that my flywheel teeth is damaged? Should I try replacing my starter first and then see if I still get this problem?
Old Mar 6, 2008 | 12:59 PM
vshavoc's Avatar
Yea replace the starter and go from there. Normally it'll make a grinding noise when it is damaging the flywheel. Usually that only happens when the starter's gear shaft gets stuck out. And if its the flywheel it would be doing it all the time not just sometimes. Know what I mean?
Mac2118
12
Feb 20, 2016 03:04 PM
egtony
Jun 11, 2009 10:48 AM
pouponu
Dec 2, 2005 12:45 PM
kmf0211
Jul 3, 2005 03:39 PM
lke2drvgsr
Jun 4, 2004 02:42 PM
