Turn signal issue.
Old Mar 5, 2008 | 12:21 PM
MugenMaster's Avatar
Default Turn signal issue.
THe other day i noticed my turn signal wasnt working. So i changed my fuse and started my car. They still didnt work. So i went to turn off my car and pulled the key out. Car still ran. So i pulled out the fuse and then it turned off my car. While the car was off i plugged the fuse back in and my fuel pump kicked on. And a loud ringing came from my distributor area. Anyone know what might be causing this.
Old Mar 5, 2008 | 12:26 PM
Former User's Avatar
Default Re: Turn signal issue. (MugenMaster)
Your ignition switch is likely bad.
The turn signal issue, on the other hand, may be due to a bad relay or combination switch.
Old Mar 5, 2008 | 12:41 PM
[ivi]'s Avatar
Default Re: Turn signal issue. (RonJ@HT)
Is your SRS light stuck on?
Old Mar 6, 2008 | 10:29 AM
No its not stuck on.
Albondigas XXG
Honda Civic (2001 - 2005)
Aug 28, 2015 06:15 AM
chrisff521
Mar 6, 2010 08:02 PM
Cory Matthews
Jun 8, 2006 03:13 PM
rolledthatho
Nov 20, 2005 07:48 AM
moleodonuts
Sep 13, 2005 02:00 PM
