What is wrong?
Old Mar 5, 2008 | 11:34 AM
kidwit93delsol's Avatar
Default What is wrong?
I'm not entirely sure what the problem is, Im thinking it may have to do with the clutch switch. (not sure the exact name)
Problem:
Push clutch in, and go to turn key. And most of the time all I get is a click, ocassionally it will even turn over (not a full turn tho while still not starting)
It happens mostly, i think when its cold, but does not happen all the time. My battery has more then enough volts. Its around 13.3 at a stand still, and 14.7 while running. I think I mentioned everything, if not, I will add in more information. Thanks
Old Mar 5, 2008 | 11:44 AM
dr.garagetuner's Avatar
Default Re: What is wrong? (kidwit93delsol)
check for loose ground wires.
Old Mar 5, 2008 | 11:46 AM
Default Re: What is wrong? (dr.garagetuner)
Never thought of that option, is there an ideal location I would check for this issue im having?
Old Mar 5, 2008 | 11:48 AM
93whtlx's Avatar
where the neg. off the battery goes to the tranny
Old Mar 5, 2008 | 11:56 AM
Kuchtaboy's Avatar
you're sure your battery is fine? what's the CCA right now? I say get the battery tested if a loose ground doesn't fix it.
does it only happen when it's cold, or does it happen at other times too?
Old Mar 5, 2008 | 12:08 PM
Slow91_JDM_Si's Avatar
Possibly Loose ground on the Tranny, same thing happned to me when i did a motor swap and went to start. Broke the ground off the tranny.
Old Mar 5, 2008 | 12:14 PM
hrs-parker's Avatar
Default Re: (Slow91_JDM_Si)
try your batter ground/grounds...if not your alternator is not pushing enough volts out....even at 11amps your not gonna get it to jump...since its cold...im sure its your alternator...change it...you need atleast 14amps to start it up..try it..im pretty sure its that
Old Mar 5, 2008 | 12:18 PM
[ivi]'s Avatar
Default Re:
Sounds like somethings not grounded correctly. Check the tranny ground, battery, relays, etc..
Old Mar 5, 2008 | 12:30 PM
Default Re: Re: ([ivi])
Im going to check the grounds. Im out ruling the alternator tho. All I have to do when it does this, is keep turning the key on and off until it starts. Although I do appreciate your advice. It will start after I keep trying(I should have mentioned that sooner i guess. Sorry) so that would mean the battery is fine as the alternator. Right?
Old Mar 5, 2008 | 12:41 PM
Former User's Avatar
Default Re: Re: (kidwit93delsol)
Make sure both battery connectors and terminals are clean and making good electrical contact. Corrosion might be restricting current flow from the battery.
nothing_shocking
12
Apr 9, 2014 09:51 AM
Mentat Ghola
Feb 7, 2010 10:54 PM
Flexin5
Jul 19, 2007 06:17 PM
9311dan
Nov 13, 2006 05:44 AM
lacking vtec
Jul 3, 2006 01:54 PM
