Type R throttle body on B16 in CRX
Old Jul 7, 2002 | 05:18 AM
spettinger's Avatar
Default Type R throttle body on B16 in CRX
hey-- trying to figure out what is necessary to wire in a Type R throttle body with the electric map sensor to a 91 CRX SI. thanks
Old Jul 7, 2002 | 05:42 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Type R throttle body on B16 in CRX (wreckedhatch)
Nothing really.
Use the MAP sensor in the ITR T/B and just lenghten the wires so they reach the
sensor. That's it.
Old Jul 8, 2002 | 10:48 PM
JUNcr-x's Avatar
Default Re: Type R throttle body on B16 in CRX (Spaceballs the lunch box)
Nothing really.
sensor. That's it.
Old Jul 9, 2002 | 03:30 PM
EFCIVIC_810's Avatar
Default Re: Type R throttle body on B16 in CRX (b18t4_crx)
how much big of a difference does the throttle body make?
is it better then the skunk 2 throttle body?
Old Jul 9, 2002 | 03:56 PM
customx_'s Avatar
New User
Default Re: Type R throttle body on B16 in CRX (EFCIVIC_810)
not much diff at all. its like putting a bigger opening on a straw.
now get an itr intake mani!
Old Jul 9, 2002 | 04:11 PM
island_son's Avatar
Default Re: Type R throttle body on B16 in CRX (mindtrix)
Or take off your intake manifold and use a dremel to open up the hole for the throttle body.You can even polish it with the dremel, make sure it's clean befoe you install the manifold back on the head. And you just saved yourself a few hundred dollars.
Xtream_V
May 30, 2011 06:41 AM
h2point2
Aug 27, 2007 08:08 PM
Sanj
Sep 29, 2005 09:03 PM
coupe_hybrid
Aug 27, 2004 09:39 AM
skafia
Mar 5, 2003 08:01 AM
