LSD interchange
What's the spoon spool out of? Here's the interchange:
Integra LS and B16 shares the same ring gear bolt pattern.
Integra GSR and Type R share the same bolt pattern.
So, if you have a B16 spool and you want to put it in a Type R trans, it won't work if you want to use the same ring gear since the bolt pattern is different.
Ryan
Ryan
Okay, just spoke to my mech. He says I need to open up my gearbox before knowing if the DC2R LSD can be a direct replacement with my present LSD. He mentions something about the size of the LSD. He says this is mainly because I do not have a stock DC2R or EK9 final drive.
Does anyone know if Spoon LSD comes in 2 sizes as well for the B-series gearbox? This will narrow down my search.
