skunk2 intake manifold question
Old Mar 5, 2008 | 04:12 AM
polishedturd's Avatar
I like PIE
Default skunk2 intake manifold question
i have a 95 gsr and i am installing a skunk2 IM, my question is can i install it and use the stock gsr throttle bracket and cable or do i need the type r cable and bracket? will the hood close?
also i have the hondata IM gasket that im installing with it, what size bolts will i need to replace the factory studs? thanks for any help
Old Mar 5, 2008 | 09:29 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: skunk2 intake manifold question (polishedturd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 gsr and i am installing a skunk2 IM, my question is can i install it and use the stock gsr throttle bracket and cable or do i need the type r cable and bracket? will the hood close?
also i have the hondata IM gasket that im installing with it, what size bolts will i need to replace the factory studs? thanks for any help</TD></TR></TABLE>
I put one of these in my 99 GSR. I used the hondata gasket as well. I didn't need to back out the studs or get new ones. I just bolted it on. The nuts still torqued to 18ft/lbs. You can back the studs out a little bit by using the jam nut method.
There is a way around using the ITR throttle cable/bracket. I have a very crude diagram. I did this with mine, and still used the stock strut tower bar, and had absolutely no hood issues.
Old Mar 5, 2008 | 10:09 AM
I like PIE
Default Re: skunk2 intake manifold question (B serious)
cool thanks, ill try that.
the gasket i have is actually the password jdm version. is it still the same thickness?
Old Mar 5, 2008 | 10:25 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks, ill try that.
the gasket i have is actually the password jdm version. is it still the same thickness?</TD></TR></TABLE>
Should be.
EG6Marcus
Feb 15, 2011 03:54 PM
ganjasnack
May 31, 2009 02:41 PM
BG-Teg
Jul 9, 2007 09:52 PM
95GSRDC2
Jun 12, 2007 12:27 AM
Havokgsr
Apr 9, 2003 09:02 AM
