BluePrint K20 ALL MOTOR build
Old Mar 4, 2008 | 06:01 PM
BluePrintmfg.com's Avatar
Banned
Default BluePrint K20 ALL MOTOR build
Here are some pictures of a recent build here at the shop.
Specs
<u>Head</u>
PRB head with bp stage 2 port & polish
BP stage 3 cams
BP valve springs & titanium retainers
BP head studs
<u>Block</u>
K20A2
Stock sleeves
Wiseco custom 86.5mm pistons
-13:1 compression
-thermal barrier coating
BP Pro I-beam connecting rods
K20 crankshaft
-4 lbs removed
Parts layout and block before assembly
Shot of one of the ports. The head flowed ~330 cfm @ 28'' of water
Valves and combustion chambers.
shot of the crank. 4 lbs removed from the counterweights, balanced, and micropolished.
Block with the OEM Honda bearings inserted and lubed for the crankshaft.
Crank resting in the block
Mains installed
Torquing down the mains
Old Mar 4, 2008 | 06:16 PM
Banned
Default Re: BluePrint K20 ALL MOTOR build (BluePrintmfg.com)
BP PRO I-beam rods
Measuring the rods
Close up shot of one of the thermal coated pistons
Stock sleeves @ 86.5mm. Finished with a diamond honing stone
Piston/rod being installed with wiseco ring compressor made for 86.50mm
Pistons and rods installed
BP head studs
OEM HONDA head gasket
Head being torqued down
Leakdown test
Head on block
The customer will be completing the assembly and installing the engine into a civic eg for street/drag racing. Pictures of the finished engine and dyno charts should be coming in the next week or two
Old Mar 4, 2008 | 07:00 PM
Rony_typer's Avatar
nice set up. how much would it cost to do the same on a k24 block me putting the parts. thx
Old Mar 5, 2008 | 04:59 AM
mar778c's Avatar
Community Builder
Community Influencer
That is a very nice set-up.
330 cfm head, amazing.
Old Mar 5, 2008 | 06:47 AM
WHTZ's Avatar
Default Re: BluePrint K20 ALL MOTOR build (mar778c)
Sick build
Old Mar 5, 2008 | 09:42 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">That is a very nice set-up.
330 cfm head, amazing. </TD></TR></TABLE>
Thank you, we are hoping to get the dyno results soon.
Old Mar 5, 2008 | 09:49 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Do you have a flowsheet for the head?
Old Mar 5, 2008 | 09:57 AM
itgsr98's Avatar
Default Re: BluePrint K20 ALL MOTOR build (rochesterricer)
Is that coating you did to the pistons, done in house. If so is it a service you offer to customers. Nice Build. In for finished results.
Old Mar 5, 2008 | 10:13 AM
alterdcreations's Avatar
Default Re: BluePrint K20 ALL MOTOR build (itgsr98)
nice build
curious, are you guys sponsors?
Old Mar 5, 2008 | 10:40 AM
Banned
Default Re: BluePrint K20 ALL MOTOR build (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">nice build
We were sponsors not to long ago, but since the sponsor prices have sky rocketed we have not had the chance to be a sponsor again.
Old Mar 5, 2008 | 11:29 AM
you guy do nice work.
looking to see the outcome of this build.
Old Mar 5, 2008 | 01:45 PM
BolivianFuego's Avatar
Good ****! Subscribed.
Old Mar 5, 2008 | 04:11 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">you guy do nice work.
Thank you, we will be building a B-series stroker motor very soon and will have it posted very soon.
Old Mar 5, 2008 | 04:24 PM
89hatcher's Avatar
great build...looking forward to see the dyno graphs
Old Mar 5, 2008 | 05:06 PM
flyrod's Avatar
Default Re: BluePrint K20 ALL MOTOR build (BolivianFuego)
Thanks for sharing this build with us. How high are you planning to rev? Are you keeping the piston oil squirters? Any mods to the oil pump or oil baffling? Good luck on the dyno and keep us posted!
Old Mar 5, 2008 | 05:40 PM
UncleD's Avatar
Default Re: BluePrint K20 ALL MOTOR build (flyrod)
After this season, I'm done with B. What header/IM is the customer gonna run? Build looks
Old Mar 6, 2008 | 07:40 AM
b19coupe's Avatar
This should be interesting.
Old Mar 6, 2008 | 08:21 AM
HYBRID FREAK's Avatar
Nice.
Old Mar 6, 2008 | 08:50 AM
98vtec's Avatar
moderator emeritus
Default Re: (HYBRID FREAK)
be sure to post dyno's, flowcharts, ET's...etc so this thread will not be just a thread filled with cool pictures and "props" posts in a tech forum.
Old Mar 6, 2008 | 10:33 AM
Banned
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">be sure to post dyno's, flowcharts, ET's...etc so this thread will not be just a thread filled with cool pictures and "props" posts in a tech forum.</TD></TR></TABLE>
Not a problem, we are waiting on the dyno results from church automotive which should be very soon, and hopefully some ET's from the customer if he gives us the permission for that info. to be posted.
Old Mar 6, 2008 | 01:53 PM
GUILOTINE's Avatar
Kill Gil
Ben does amazing work. Can't wait untill he gets my K24
-Gil
Old Mar 8, 2008 | 08:14 PM
A-'s Avatar
A-
Default Re: (GUILOTINE)
Old Mar 12, 2008 | 02:56 PM
George Knighton's Avatar
H-T Order of Merit
Several moderators reported this thread as one that was advertising. However, it seems to me that if we allow a little latitude with it, and if the poster can promise not to sell things and take unfair advantage of the opportunity, that perhaps there is a chance to learn from it.
If things take a wrong turn, the forum moderators can lock it again.
Old Mar 12, 2008 | 03:45 PM
dinko's Avatar
Default Re: BluePrint K20 ALL MOTOR build (George Knighton)
Thanks for sharing
Old Mar 12, 2008 | 06:36 PM
eg6_itb's Avatar
NICE!!!!!!!!!
