f/s Nebraska 90 Integra LS JDM B20B
Old Mar 4, 2008 | 05:07 PM
nastynutsnash's Avatar
Default f/s Nebraska 90 Integra LS JDM B20B
90 Integra LS
180,xxx miles on the chassis
white/black exterior (needs paint)
good
no typical honda rust
minimal dings
bad
would need a paint job
someone keyed the driver side door
needs a windsheild
dent in the hatch
new front fenders (black primer)
new front bumper (black primer)
super clean'd tails(no pink lines)
antenna block off accord
ALL OLD body panels will be included
blue interior w/ black seats
good
MINT GSR seats
everything works
bad
wear spot on the carpet by gas pedal
driver side door panel has a crack
no stereo system
Motor
JDM B20B 9.6 C/R w/ RARE P8R head(33mm intake valves and flows similar to a VTEC head)
OEM intake tube w/ a cone filter
Megan Racing header
EBAY race cat
themal cat-back
energy suspension poly inserts & shifter bushings
unknown 6 puck clutch
B&M short shifter
Buddy Club race battery
New OEM plugs
good running motor (drove it 7 hours to get it home)
1 pinhole in the coolant line to the throttle body(just happend)
NO LEAKS of oil or anything else besides what was already stated
bads
NO A/C
NO P/S
NEEDS A WINDSHEILD
things included
MINT JDM 1 peices
PWJDM conversion harness
PWJDM H4H bulbs
Skunk2 Full coilovers PRO-S
OEM Rear LCA's w/ poly bushings
XS intake manifold
OEM Honda IM gasket
OEM Honda TB gasket
also included is a front end kit
new upper control arms
new lower ball joints
new inner and outer tie rods
new front sway bar end links
pics(shitty but they work and if your serious come look at it)
start out at 5k OBO
High price because i mostly want trades
mostly accords(90-93 NO RUST 5spd)
hatch's will also do
Si's are NOT included if a trade is made you keep yours i keep mine
feel free to call me at 402-813-2644 my name is mike
Modified by nastynutsnash at 10:04 AM 3/16/2008
Old Mar 5, 2008 | 03:22 AM
Default Re: f/s Nebraska 90 Integra LS JDM B20B (nastynutsnash)
ttt
Old Mar 5, 2008 | 03:40 AM
J's 94 Accord's Avatar
Does the motor have a knock sensor?
Old Mar 5, 2008 | 05:39 AM
Default Re: f/s Nebraska 90 Integra LS JDM B20B (J's 94 Accord)
it is
they are the only ones w/ p8r heads(33mm intake valves)
Modified by nastynutsnash at 5:35 PM 3/5/2008
Old Mar 5, 2008 | 04:36 PM
up
Old Mar 5, 2008 | 05:54 PM
jdm_cert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J’s 94 Accord &raquo;</TD></TR><TR><TD CLASS="quote">Does the motor have a knock sensor?</TD></TR></TABLE>
OoOoO
Old Mar 5, 2008 | 06:19 PM
Default Re: f/s Nebraska 90 Integra LS JDM B20B (jdm_cert)
up
Old Mar 6, 2008 | 03:08 AM
up
Old Mar 6, 2008 | 04:53 AM
so it does have a knock sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nastynutsnash &raquo;</TD></TR><TR><TD CLASS="quote">it is
Modified by nastynutsnash at 5:35 PM 3/5/2008</TD></TR></TABLE>
And no, the ones with knock sensors ARENT the only ones that have P8R head....
Old Mar 6, 2008 | 05:35 AM
thats what i thought
so you wanna by or are you just bs'n
Old Mar 6, 2008 | 06:53 AM
interested.
Thats why I'm asking you if it has the knock sensor or not.
Do you have papers/receipts for the motor as well?
Old Mar 6, 2008 | 12:42 PM
I have the tag for the motor (it was swapped down in missouri) by the previous owner
i do know its legit
Old Mar 6, 2008 | 06:21 PM
upppppp
Old Mar 7, 2008 | 10:12 AM
up again
Old Mar 7, 2008 | 02:39 PM
and up again
Old Mar 8, 2008 | 08:23 AM
godruler's Avatar
its true, there were also 9.2:1 compression P8R's that did'nt have a knock sensor, these were the older ones.
Old Mar 16, 2008 | 09:05 AM
Default Re: f/s Nebraska 90 Integra LS JDM B20B (godruler)
up
for new post and wanted trades
CLEAN TRADES ONLY NO JUNK
Old Mar 16, 2008 | 03:57 PM
also im replacing the injector seals tomorrow
one leaks bad since the manifold swap
lPat
Texas -OK -LA (Sales)
Oct 10, 2007 04:07 PM
CarbonCreations
Northwest (Sales)
Nov 20, 2005 06:10 PM
mnjh94
Oct 19, 2005 01:19 AM
mnjh94
Oct 10, 2005 10:21 PM
mnjh94
Oct 4, 2005 10:20 PM
