just got a ls block and the crank will not move at all
Old Mar 4, 2008 | 04:58 PM
vtechachey's Avatar
Default just got a ls block and the crank will not move at all
let me know what it can be thx
Old Mar 4, 2008 | 05:21 PM
DA_9's Avatar
Default Re: just got a ls block and the crank will not move at all (vtechachey)
A royally [freak]ed motor
Old Mar 4, 2008 | 06:06 PM
vtechachey's Avatar
can the crank be bent or sum ****
Old Mar 4, 2008 | 06:38 PM
JoePSI's Avatar
Is the timing belt on or off?
Old Mar 4, 2008 | 06:57 PM
vtechachey's Avatar
i just got the block its not on the car
Old Mar 4, 2008 | 06:59 PM
JoePSI's Avatar
Take the oilpan off and have a look if its just the block.
Old Mar 4, 2008 | 07:04 PM
vtechachey's Avatar
what do u mean if it's just the block ? and can it be that the crank is just bent ?
Old Mar 4, 2008 | 07:06 PM
JoePSI's Avatar
Since you have the block already bare just take it apart. If you have to take the crank to a machine shop and check it
Old Mar 4, 2008 | 07:10 PM
vtechachey's Avatar
it's got the pistons in it and **** still or can i put my b20 crank in it but than i will need new rod bearings and crank bearings right
Old Mar 4, 2008 | 07:12 PM
vtechachey's Avatar
and balanc the crank
Old Mar 4, 2008 | 07:16 PM
JoePSI's Avatar
I personally wouldn't risk building an engine that has any possibility of being in jeopardy prior to starting up. Take it and get it balanced and make sure everything you put in it is up to par. While you got it out get the crank knifeedged and get some fresh sleeves in ur block
Old Mar 4, 2008 | 07:19 PM
vtechachey's Avatar
i am going to see what i can do thx for all of the help
Old Mar 4, 2008 | 07:23 PM
JoePSI's Avatar
np, welcome to H-T
Old Mar 4, 2008 | 08:52 PM
95 integra's Avatar
Most likely a spun rod bearing....which isnt a quick and easy fix by any means.
pokie
11
Jun 20, 2010 07:23 PM
d16dcoe45
Oct 25, 2006 03:52 PM
Pandahatch
28
Feb 27, 2006 08:08 PM
Pandahatch
Feb 26, 2006 10:08 AM
