Getting Spoiler Off HELP
Old Mar 4, 2008 | 02:35 PM
jawsiiv's Avatar
Default Getting Spoiler Off HELP
Problem: Spoiler is Fiesta Platter on the back of my EG DX.
Screws will not come off with screw driver OR with WD40 and Screw Driver
Suggestions folks cause I do not want get the mighty hammer out....
Old Mar 4, 2008 | 02:50 PM
1992Si's Avatar
Photo's ????
Old Mar 4, 2008 | 03:08 PM
id3379's Avatar
check mabie there are nuts on the other end of them ? can't really tell you without a pic
Old Mar 4, 2008 | 07:02 PM
jawsiiv's Avatar
Default Re: (id3379)
Cant get to back of screws. They are under the spoiler
Here are pics though. The first picture is counter clockwise
Old Mar 5, 2008 | 06:04 AM
jawsiiv's Avatar
Default Re: (jawsiiv)
Bzzzump cause I need info
Old Mar 5, 2008 | 09:36 AM
blk92_d16's Avatar
Take a rotory tool and cut a straight line across the top. Use a cordless drill and torque it off. I had to do this with a couple rusted bolts of my own...including the TPS sensor.
Old Mar 5, 2008 | 09:38 AM
1992Si's Avatar
I'll view photo's when I get home.
Old Mar 5, 2008 | 10:07 AM
jawsiiv's Avatar
Default Re: (1992Si)
Was talking to a dude today. He said a Dremel with 35,000 RPM from a hardware store should be able to slice the heads off. If it did work how would a get the actually screw out without the head. Sorry for the questions, but I need this off fast, cause I want to sell this Donkey
Old Mar 5, 2008 | 01:46 PM
1992Si's Avatar
They look like #2 Phillips or Torq-bits I have had good luck using small needle nose vise-grips to remove some screws.
If you ever do this again use hex head bolts.
Old Mar 5, 2008 | 02:25 PM
93whtlx's Avatar
I do sheet metal for a living on aircraft. We get rusted screws all the time. Get a drill bit that is .098-.128 in size and drill into the head and just into the shaft enough to get an easy out in it. Use some vice grips or a tap and screw it out. Works all the time. tried and true.
Old Mar 6, 2008 | 06:10 PM
jawsiiv's Avatar
Default Re: (93whtlx)
UPDATE
1992 Si, I did not put the spoiler on. Trust me if I did I would have never used Phillips.
Thanks 93whtlx, what you told me did the trick. Here are updated pics. Sorry for the size.
Old Mar 6, 2008 | 06:24 PM
slacks's Avatar
yikes!!!! that was a wiley one!
good luck with that de-ricing
hmongyaj87
Jun 16, 2007 03:15 PM
Spectrum24x
Jan 5, 2006 12:37 PM
Spectrum24x
Jan 4, 2006 11:06 PM
lilbastrd
Honda S2000
57
Mar 8, 2005 09:16 PM
mickey513
Mar 11, 2002 03:21 PM
