help with head of D16A6
Old Mar 4, 2008 | 12:30 PM
crxboi90's Avatar
Default help with head of D16A6
well the problem is that i recently rebuilt my d16a6 from my 1990 honda crx si and the problem is that i followed the torque sequence taking off the head but when i put the head back on i forgot to follow the torque sequence and now my car wont start, radiator builds up lots of pressure and busts, and one time i tryed to start it i heard a lout popping noise like a mellow backfire within my engine someone please help thanks
Old Mar 4, 2008 | 12:58 PM
SIred91's Avatar
Rainman
Default Re: help with head of D16A6 (crxboi90)
Sounds to me like your timing is WAY off.....
What do you mean your "radiator builds up lots of pressure and busts"?
Old Mar 4, 2008 | 01:21 PM
crxboi90's Avatar
Default Re: help with head of D16A6 (SIred91)
like i put fluid in and when i start it the radiator hoses expand and bust i dont know how it builds up that much pressure so fast cause on only try in start it for like 4 seconds at a time but yeah that might be a separate issue so how do i fix my timing so me torquing the head bolts wrong may not be the problem
Old Mar 4, 2008 | 01:36 PM
SIred91's Avatar
Rainman
You have a problem with the headgasket. Period.
Did you replace it? And yes, following the correct torque sequence is a must.
Or this exact situation will occur.
All the pressure from your pistons compressing the charge is going straight into your cooling system.
Fix your headgasket.
Old Mar 4, 2008 | 01:38 PM
crxboi90's Avatar
thank you i am bout to buy a new gasket set right now and i will have it replaced soon thanks again peace bout to tear down the motor again
Old Mar 4, 2008 | 01:52 PM
SIred91's Avatar
Rainman
pyarrau
Jun 28, 2016 02:16 AM
ronqqq
Oct 24, 2006 08:59 PM
eg crunkmonster
Feb 6, 2005 06:23 PM
shiftinPastU2
Dec 30, 2004 09:30 AM
sparknblaze
Jul 10, 2003 05:38 AM
