FS/FT/TW: Built RHD S13 240sx *GT2871R, Works, Bride, Stance, Nardi***Clean as F@#$*** Minneapolis
Old Mar 4, 2008 | 09:35 AM
HYPERION-X's Avatar
Default FS/FT/TW: Built RHD S13 240sx *GT2871R, Works, Bride, Stance, Nardi***Clean as F@#$*** Minneapolis
I'm located in Minneapolis, Minnesota. If you want to buy it or trade you need to come here or relatively close to here as I don't have the time to travel too far.
I will consider a variety of options like an Integra (DC or DA), EK with a K20, EF with a K20, RSX, or at least something with a back seat. I want something clean.
I bought the car in February 2007. It already had an SR (about 35000 miles) in it and was converted to RHD that was very cleanly (cleanly?) done. No rust anywhere at all. As mentioned the car was very clean when I bought it.
From there the entire car was stripped, including the glass, and was put on a wooden dolly for paint/bodywork. The whole car was painted inside and out. As you’ll see the side markers, squirters, badges, and antenna have been shaved. Every single part on the car was touched. It was either replaced by new OEM, new aftermarket, or was reconditioned and painted.
There was a lot of custom work done too. It’s not noticeable in the pictures but the firewall was smoothed out with fresh steel along with where the battery sat and on the opposite side.
You will notice that there is no brake booster. We custom installed a Wilwood Pedal Box and Wilwood Master Cylinders, which have been relocated behind the gauge cluster. The cable e-brake was removed and replaced with a K-Sport hydraulic e-brake.
The wire harness was completely reworked with all of the unused wires deleted. Almost all of the harness has been wrapped in a mesh sheath and was tucked.
There is no ac, though it does have heat. I kept the heater core and wired in a fan to the back of it that is controlled from the ARC panel. We made brackets that are riveted to the floor that aim the heat on the driver’s feet. It works really well.
This car is super clean. I’ve gotten lots of positive feedback from everyone that has seen it in person. From your average Joe to enthusiasts, to the best drifters in my area, some of who have their Formula D license.
I have way over $20k in this car with receipts to prove it. I have pictures throughout the whole build. There is probably a lot more I’m missing.
PAINT & BODY
· Taffeta White paint
· Fenders rolled and slightly pulled
· Shaved badges, rear side markers, antenna, wiper holes (No wipers or wiper motors)
· Silvia Conversion
· Aero Catch Hoodpins (Locking)
· Circuit Sports Hood Dampers
WHEELS
· Work Emotion XD9 I Matte Bronze
· Front 17x8.5 +27 & Rear 17x9.5 +17
· Tires – Federal 595 – Front 215/40/17 & Rear 235/40/17
SUSPENSION & BRAKES & STEERING
· Stance GR + Pro Coilovers
· Custom solid subframe mounts
· Front tension rods
· RUCA
· Traction rods
· Toe rods
· Brakes – (z32 30mm 300zx TT) calipers and rotors
· Hawk HPS Performance Street Compound Pads Front & Rear
· Full Stainless Brake lines
· Hydraulic E-brake – K-Sport
· 5 lug hubs – Attain
· FRS Aluminum Steering Bushing
ENGINE & DRIVETRAIN
· Turbo – Garret GT2871R .64ar
· DC Sports Exhaust Manifold
· Coated Turbo & Exhaust Manifold
· HKS Exhaust
· DRFT turbo lines
· New OEM Turbo Inlet Gasket
· Mr. Gasket Exhaust Manifold Gasket
· Apexi Intake
· Z32 MAF
· DeatschWerks 740 cc Injectors
· Walbro 255 Fuel Pump
· Braided –6 Fuel Lines
· New OEM Z32 Fuel Filter
· Freddy Intake Manifold (Cleaned up and painted)
· Cams - HKS 264 in/ex step 1’s
· Cometic Head Gasket
· Decked head
· ARP Headstuds
· Greddy Downpipe w/extension
· Megan Testpipe
· Turbo Elbow
· Rom Tune – Enthalpy
· FMIC – Custom Sandwich Mount
· Custom Intercooler Piping
· ATP Silicone Couplers & T-Bolt Clamps
· Tial 50mm blow-off valve
· Kaaz 2-way LSD (Properly broken in)
· 2-Piece Driveshaft
· SPL Urethane Tranny Mount
· Koyo Aluminum Radiator
· New OEM Thermostat
· New OEM Timing chain
· New OEM Water Pump
· Electric Fans & Thermostat
· Circuit Sports Coolant Reservoir
· Circuit Sports Catch Can
· HKS D1 Limited Edition Oil Cap
INTERIOR
· Clean uncracked dash
· (2) Bride Brix II w/Bride MO Rails (Real with documentation)
· Nardi Sport Type A steering wheel w/Momo hub
· Autopower 4-point Race Roll Bar
· Gauges – STRi Boost, Oil Pressure, Oil Temp, & Coolant Temp
· Wilwood Custom Pedal Box Setup
· Wilwood master cylinders relocated under the dash
· Tomei Duracon shift ****
· C’s short shifter
· ARC 4 Panel Switch
· New OEM Shift Boot
· 5-Point Harnesses
PICS
Bodywork
Painted
Being Built
Engine
Rolling
Modified by HYPERION-X at 10:27 AM 3/24/2008
Old Mar 4, 2008 | 10:40 AM
MJobe's Avatar
Default Re: FS/FT/TW: Built RHD S13 240sx *GT2871R, Works, Bride, Stance, Nardi***Clean as F@#$*** Minneapol
Let me be the first to say, This thing is hott
Old Mar 4, 2008 | 02:25 PM
talespinc's Avatar
* B A N N E D *
WOW, this is SUPA HOT!!!!
Old Mar 4, 2008 | 03:43 PM
isaacEK's Avatar
CLEAN!
Old Mar 4, 2008 | 04:22 PM
HYPERION-X's Avatar
Thanks fellas!
Title in hand, no lien.
Old Mar 4, 2008 | 04:32 PM
MyLilCivic's Avatar
Old Mar 5, 2008 | 08:06 PM
bizzlekip's Avatar
Trade???http://hondamarketplace.com/zerothread?id=2208798
Old Mar 5, 2008 | 08:56 PM
jdmekrobot's Avatar
Default Re: (bizzlekip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MJobe &raquo;</TD></TR><TR><TD CLASS="quote">Let me be the first to say, This thing is hott </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by talespinc &raquo;</TD></TR><TR><TD CLASS="quote">WOW, this is SUPA HOT!!!!</TD></TR></TABLE>
i guess im third.
this is HOT!
i want it.
Old Mar 6, 2008 | 05:24 AM
HYPERION-X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bizzlekip &raquo;</TD></TR><TR><TD CLASS="quote">Trade???http://hondamarketplace.com/zerothread?id=2208798</TD></TR></TABLE>
I'd consider it depending on how much cash you'd throw in the deal.
Modified by HYPERION-X at 10:27 AM 3/6/2008
Old Mar 6, 2008 | 06:16 AM
jonshonda's Avatar
Community Builder
Very Nice!!
Old Mar 7, 2008 | 11:27 PM
bizzlekip's Avatar
how much would it take?
Old Mar 9, 2008 | 07:23 PM
608 Gangsta's Avatar
https://honda-tech.com/zerothread?id=2243000 !!
Old Mar 9, 2008 | 07:28 PM
VRD^sam's Avatar
Bumps for a nicely built 240
Old Mar 9, 2008 | 07:35 PM
KENetics1's Avatar
i think i have to go change my underwear now
Old Mar 10, 2008 | 08:22 AM
HYPERION-X's Avatar
PM'd 608 Gangsta and bizzlekip.
Old Mar 10, 2008 | 11:49 PM
KENetics1's Avatar
Default Re: (HYPERION-X)
not that I could afford it, but how much would you be looking to get selling price no trade?
Old Mar 11, 2008 | 07:31 AM
MasterFunk's Avatar
bump. this car is ballin.
Old Mar 11, 2008 | 08:04 AM
EGfreek's Avatar
http://www.hondamarketplace.com/zerothread/2242918
trade plus cash or what would it take to buy outright??? PM ME!!!!
AND WOW!!!!!!!!!!!!!!!!!!
Old Mar 11, 2008 | 08:32 AM
LUXXXX's Avatar
Old Mar 17, 2008 | 03:46 PM
317's Avatar
317
i've seen this in person. cleanest build i've ever seen. plus, the owner is a standup guy.
Old Mar 18, 2008 | 11:25 AM
jdmoptiontune's Avatar
I wouldn't even drive it just stare at it Bump cuz it can do a mean burnout!
Old Mar 18, 2008 | 02:53 PM
M_W A_R_M_Y's Avatar
HOTTTTTT AS HELLLL
Old Mar 19, 2008 | 09:07 PM
ICKEST's Avatar
pmed'
Old Mar 24, 2008 | 06:27 AM
HYPERION-X's Avatar
PM's responded to.
Old Mar 24, 2008 | 07:02 AM
stein_k_9's Avatar
sick *** silvia. coupes ftw!!!!
