b18 intermediate shaft and axles compatability
Old Mar 4, 2008 | 08:52 AM
D16SiHatch's Avatar
Default b18 intermediate shaft and axles compatability
k so this is my current project. swapping a b18b1 from a 94 teg into my 91 Si hb. (removal of donor motor is in progress lol)
The bad thing is it has an auto tranny bolted to it now, which i will not be using. Im curious as to whether or not i can use the axles and or the intermediate shaft from the auto tranny on the manual (90-93) A1 tranny that i'll be getting?
and if i do need a diff intermediate shaft do i use the one from the manual transmission that would of came on the car had it been a manual, or can i use one from a b18a1? I know the DA axles will work but i was just curious if the auto axles on it now could be of any use to me.
Old Mar 4, 2008 | 10:53 AM
D16SiHatch's Avatar
Default Re: b18 intermediate shaft and axles compatability (D16SiHatch)
Ok so i did some digging and determined that the intermediate shafts in the Auto and manual transmission are different. i know i need to get a 90-93 Manual intermediate shaft for my cable A1 trans.
Now i'm still left with the question about the axles. I checked advance auto parts website and compared the parts numbers. it appears the 90-93 axles are identical to the 94-01 axles. There are abs and Non-abs axles available i noticed. I believe the axles in my donor teg are ABS because its an LS as far as i know, not RS. That being the case im prety sure i read somewhere some guy who said the ABS axles work just the same as the non abs models, is this the case?
Old Mar 4, 2008 | 11:05 AM
IT GUY's Avatar
90-93 passenger side axles are the same as 94+
on the drivers side the 90-93 intermediate shaft is female, so both ends of the axle are male
on the drivers side the 94+ intermediate shaft is male, making the axle female on the intermediate side.
I've heard conflicting things about the ABS axles working. I believe that they do, but I'm sure someone else can give a more definitive answer.
Old Mar 4, 2008 | 11:16 AM
northemt88's Avatar
sound bad but get ebay, they have mount and axle set for like 2 or 3 hundred and they work great.
My friends been running them for 2 yrs now no probs.
Old Mar 4, 2008 | 01:50 PM
Crx Jimmy's Avatar
Default Re: (northemt88)
yes the axles will work fine, just get the proper manual intermed shaft
Old Mar 4, 2008 | 02:29 PM
D16SiHatch's Avatar
Default Re: (Crx Jimmy)
thank you for the clear answer sir
Eli2
12
Mar 23, 2009 09:51 AM
InfamousRS
May 13, 2006 11:50 PM
InfamousRS
Feb 9, 2003 03:57 PM
InfamousRS
Feb 9, 2003 11:49 AM
