How can i bypass the coolant lines to the IACV?
Old Jul 6, 2002 | 09:34 PM
Darkteg's Avatar
New User
Default How can i bypass the coolant lines to the IACV?
i've done it to the TB, but now i want to extend it to the IACV.
does anyone have any schemes?
Old Jul 6, 2002 | 09:55 PM
HybridKOOP's Avatar
Default Re: How can i bypass the coolant lines to the IACV? (Darkteg)
The line that goes into it..
And the line that goes out of it...
Run a continuous coolant line to those 2 points. I believe one is on the "cross pipe" coolant ordeal on the back of the block, the other is to the t/b..
Old Jul 8, 2002 | 06:18 AM
Darkteg's Avatar
New User
Default Re: How can i bypass the coolant lines to the IACV? (HybridKOOP)
Done!
now i have both bypasses... idle looks good when starting the car in the morning, and since our winters are not very cold, there should be no problem.
Old Oct 25, 2002 | 09:00 AM
Chris's Avatar
Back up because I need to know this as well..
Please go onto more detail.. I have removed my Heater core and am using a Hondata gasket.
I dont want water in the IM, or heater core... just to head and block, then thermo and rad.
How would I route the lines?
I wish I could find a water flow diad.. Helms only has where to put the hoses.
Mr.Death
Jul 17, 2008 04:38 PM
lude98SH
Aug 12, 2007 07:49 PM
B18 CYA
Aug 29, 2006 06:48 AM
turbotime
Nov 5, 2005 12:34 AM
