looking for IACV but where?
Old Mar 4, 2008 | 06:45 AM
immajackuup's Avatar
Default where is a good place to buy IACV for cheap?
I got this Iacv from a d15b mani and it doesn't fit on this d16y8 mani^^
I thought d series are all compatible.
Old Mar 4, 2008 | 06:59 AM
crazyguy's Avatar
Default Re: where is a good place to buy IACV for cheap? (immajackuup)
i got one from ebay before. it is a used but in good condtion.i think i paid $25 shipped.
Old Mar 4, 2008 | 07:12 AM
IIXtremeHansen's Avatar
Ebay or Junk or New ones fomr a Honda site get one off any 92+EX, it'll be cheaper.
Old Mar 4, 2008 | 07:15 AM
old man neri's Avatar
White socks with black sandals? Hmmmm.
Old Mar 4, 2008 | 07:16 AM
Default Re: where is a good place to buy IACV for cheap? (Dickies_n_FlipFlops)
imma just hit up the junk yard
well when I'm there should i buy a p2p ecu?
just doing the intake manifold swap not mini me.
Old Mar 4, 2008 | 07:17 AM
socialburn0035's Avatar
any junkyard should have one. Id bring the im with u tho. test fit it. I work at a junkyard and i put a used one on. still works. probably going on 10,000 miles. i think only the y8 and z6 will work but i could be wrong. i put a y8 IACV on my z6 im.
Old Mar 4, 2008 | 07:37 AM
jax97hx's Avatar
Default Re: (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">White socks with black sandals? Hmmmm. </TD></TR></TABLE>
x2 lol
Old Mar 4, 2008 | 07:46 AM
Default Re: (jax97hx)
**** was cold outside lol
if i reuse the p2e ecu could i use the y8 injectors? or I have to reuse the y7 injectors
Old Mar 4, 2008 | 08:01 AM
Default Re: (immajackuup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">**** was cold outside lol
if i reuse the p2e ecu could i use the y8 injectors? or I have to reuse the y7 injectors</TD></TR></TABLE>
Dont matter.
Old Mar 4, 2008 | 08:37 AM
Default Re: (Dickies_n_FlipFlops)
are you sure?
Old Mar 4, 2008 | 09:45 AM
civicjoe's Avatar
y7 injector part #06164-P2A-000
y8 injector part #06164-P8A-A00
here's the part numbers for the different stock injectors. I have been told multiple times they are the same thing. I'm not sure why they are different part numbers tho. I'm sure someone else will chime in.
EDIT: oops thought you were asking something else, he's right it doesn't matter u can reuse your injectors
Old Mar 4, 2008 | 10:17 AM
pgpbubble's Avatar
Default Re: (civicjoe)
Y7 are 190cc.
Y8 are 240cc.
Old Mar 4, 2008 | 10:39 AM
civicjoe's Avatar
Default Re: (pgpbubble)
ah thanks
Old Mar 4, 2008 | 11:48 AM
kool, less work for me if i use the y8 injectors that is already on the manifold.
Because its a bitch to pull those injectors out.
egboy94
Jan 13, 2009 02:13 PM
so simple
Northern California (Sales)
31
Jan 15, 2008 11:29 AM
LoseRPunKx182
Dec 21, 2004 04:37 PM
mrtoastyjr
38
Dec 9, 2004 09:14 AM
808EKFerio
12
Apr 2, 2004 09:47 AM
