Headlight indicator 'ding' not working
Hi all! Well, after killing my battery for the 2nd time this year, I figured it was probably time to ask for help
I drive a 99 Integra LS with a Compustar 2W8000FMR A/S, and I love my car like crazy! Had some wicked bad luck lately, but I figure things have got to start looking up soon!
Anyway, not sure when it started, but that annoying little "ding" that tells you your headlights are on doesn't work anymore.
Any quick fixes? (It'll have to be pretty specific, I'm very much a newbie to doing any of my own car stuff!) Thanks!
Im in the same boat and I REALLY wish someone would have had an answer for this lol. Any luck 4 years later?
I did a tuck on my driver side and after the tuck it doesnt ding for the headlights being left on or the key being left in. You never realize how much you enjoy an annoying little ding until its gone lol.
If so, the switch is good and your problem is most likely the ICU.
If not, check the pin switch, it may still be good and the problem will still be the ICU, but if the switch is bad the dome light will not work or will the warning chimes.
If the dome light does not come on, remove the pin switch and unplug it, ground the lead that was plugged into the switch, if dome light comes on, replace the pin switch, if not, your back to the ICU. 94
Im assuming by door pin switch you mean that little rubber button down on the bottom? Unfortunatly, my dome and map lights dont work at the moment. I think I burned them out while I was blacking out my interior. So i cant tell based off of that just yet.What ICU are you referring to? Im not sure what that is..
ICU = integrated control unit, there is only one, it will be "plugged in" to the back of the under dash fuse box.
The chimes work off the drivers door switch, it supplies a ground to the ICU when the drivers door is opened, the ICU in turn supplies a ground to the dome light circuit and to an internal circuit with key sense, head light and seat belt inputs for warning chime inputs, for head lights and key the door has to be opened to trigger chime, for seat belts all you need is to be unbuckled and ign. on.
Get your dome light working, it is the best tool to check the door pin. 94
