Studs non buyable?? need to start Dremeling! help me find...
Old Mar 4, 2008 | 05:42 AM
lmike6453's Avatar
Default Studs non buyable?? need to start Dremeling! help me find...
ok, this thread is associated with this one i created not too long ago...
https://honda-tech.com/zerothread?id=2236267
i am replacing my valve cover studs and don't know how to/ can't find the middle 3 on my rs valve cover....
and the diagram with parts for sale is this...
it's the left diagram and the studs i need are underneath nuts 21...i do see they have studs 18 and 19 for sale but what about all the others? lol
Old Mar 5, 2008 | 01:06 PM
lmike6453's Avatar
so i called acura, they pulled up the same diagram and the guy does not know
Old Mar 5, 2008 | 01:13 PM
climb_on's Avatar
Default Re: (lmike6453)
theres only 2 different studs either number 18 or 19
im not sure which ones go where but those are the only 2 they sell cause they are the only 2 you will need. you will just need to buy the right quantity of them, which im not sure what it is
Old Mar 5, 2008 | 03:35 PM
I AM WEASEL's Avatar
Default Re: (climb_on)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climb_on &raquo;</TD></TR><TR><TD CLASS="quote">theres only 2 different studs either number 18 or 19
im not sure which ones go where but those are the only 2 they sell cause they are the only 2 you will need. you will just need to buy the right quantity of them, which im not sure what it is </TD></TR></TABLE>
That is correct, I just looked and it requires 5 of one and 2 of the other
Old Mar 5, 2008 | 03:44 PM
94 IntegraLS's Avatar
Default Re: (-DC4-)
Im pretty sure you need 2 19's and 1 18 because I also had to replace those 3 studs last summer. If I remember correctly one 19 goes in the middle and then the other goes in the far right... and then the 18 goes in the far left spot. Just be careful because when I tried to remove them they were on so tight that I thought they were gonna break... but luckily they didnt. Also while your there you might wanna replace the valve cover gasket as well but you could also reuse the old one if its in good shape.
Old Mar 5, 2008 | 03:57 PM
95 integra's Avatar
Default Re: (94 IntegraLS)
Why do you need to replace the studs and what every happened with that anyway?
Old Mar 5, 2008 | 04:05 PM
Default Re: (95 integra)
I believe he stripped the old studs.
Old Mar 5, 2008 | 04:59 PM
lmike6453's Avatar
well actually i stripped the old nuts on the studs and while dremeling off the nuts, i'm going to replace the studs
Old Mar 5, 2008 | 05:32 PM
gsrjrsc's Avatar
pound a smaller socket on if you have enough room
Old Mar 5, 2008 | 06:29 PM
lmike6453's Avatar
will that break the nut?
Old Mar 7, 2008 | 04:12 PM
lmike6453's Avatar
ok i dremeled off one nut and need to get out the damaged stud...what tool from what store should i use?? and how do i do it?
94DB8
Aug 29, 2008 02:43 PM
fastrider213
Oct 18, 2007 06:20 PM
Sean @ ESG
11
Sep 10, 2005 03:52 PM
DAintegraGSR
Jun 13, 2005 10:13 AM
colombian linx
Nov 29, 2004 08:20 PM
