Need help after V2 install
Old Mar 4, 2008 | 03:58 AM
hondacivic614's Avatar
Default Need help after V2 install
i have a 98 ex i just installed a v2 intake on it yesterday.... today when i was driving it started to idle really high rpm's like id put it in neutral and itd be revving at 4000 rpm... i popped the hood and messed with the throttle and it was real stiff i was able to push it down to get it to stop revving high but it seems that the next time i give it gas its gonna get stuck again... any help?
Old Mar 4, 2008 | 04:03 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Need help after V2 install (hondacivic614)
From the sounds you describe it seems the throttle body is getting stuck. Get some throttle body cleaner and clean it...
unless you forgot to put the sensor back in..
Old Mar 4, 2008 | 04:15 AM
Default Re: Need help after V2 install (D16Y_coupe)
i put both the sensors back in... although the nipple comin off the intake for the 'recirculation air tube' is left open, i didnt have anything to put on it?....
Old Mar 4, 2008 | 04:45 AM
B16B_coupe's Avatar
HRD PKR
you delete that and run a straight coolant line from the throttle body to the head.
Old Mar 4, 2008 | 05:30 AM
TahitianEG's Avatar
Make sure that you put the TPS back into it's correct slot. I replaced my TPS and didn't get the little notch back into the correct position, and I was reving in the 4's. I'm almost 100% sure that there should be pressure on the tps. What I mean by that is, you put the TPS into it's slot, and then, in order to tighten it down, you have to turn it (clockwise I think) to align the holes to screw it into place.
dmossdrum91
Sep 20, 2015 02:16 PM
muddmonky
Dec 22, 2012 05:36 PM
TylerWestPwnz
Nov 1, 2012 01:03 PM
alvinoolivas
10
Sep 10, 2010 09:35 AM
Bakersfieldgsr
Nov 12, 2007 03:34 PM
