99-00 fogs on 97, i did front end conversion
so like title says i did a front end conversion but i was just wondering if i could run the 99 fogs on my car with the oem harness or do i need to a different wire job.
is the harness oem for the 2000 fogs or from ur original year car? if its for the 2000 it will be fine. i did my conversion about 3 weeks ago and the harness for the 2000 fogs worked out fine for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ereyesEK4 »</TD></TR><TR><TD CLASS="quote">its the 2000 harness and i will be plugging it into my 97 civic, so it should work?</TD></TR></TABLE>
Yes, all 96-00 Civics are prewired the same way, a single wire running from the engine bay to the interior.
Sorry to thread jack.
But since were talking about 99-00 fog lights. I'm trying to wire up my fog lights to the OEM fog light switch. So that it can be turned on independently and at anytime. Any one know how to wire them to the fog light switch?
everything bolts and plugs right up. im assuming that when u bought the fog lights they came with an instruction manual right? if so then just follow that if not then u can check out my write i did on installation of the fogs on a 97...
https://honda-tech.com/zerothread?id=2172348
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s »</TD></TR><TR><TD CLASS="quote">Sorry to thread jack.
Do you have an OEM harness?
Unfortunately not, at the moment the fog's are tapped into the head lights. If that makes sense, the fog lights turn on with the parking lights. I dont have a fog light switch yet. When I get one soon, I want to wire it to the fog light switch.
I was hoping to do a "diy" type wiring of the fog lights to the fog light switch.
I hope this helps...
https://honda-tech.com/zerothread?id=685131
The two wires going to the fusebox, you put those two wires in the certain slot to make them turn on without headlights.
The wire coming from the relay plugs into slot #1. The wire coming from the switch plugs into slot #4
hi im new to this moddin thing. but i have a 97 sedan. and today i bought a 99-00 bumper and i did a dry fit and it didnt fit. is there a difference between the coupe and sedan? and do i need to change the fenders to make the 99-00 bumper fit? what set up do you have on your 97 sedan? thanks
BLOCK8732
17
Apr 25, 2020 10:23 PM
BuddhaBanzai
Apr 4, 2010 08:31 PM
