Big tube tri y or regular?????
hey i have a 81.5mm ls vtec with pr3s, skunk2 pro2s, a blox intake manifold, and a gsr throttle body bored to 65mms and im tryin to decide if a big tube tri y (hytech knock off) or the regular dimension header would be my best bet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">white or dark?</TD></TR></TABLE>
Racist. You should have percentage deducted.
For your setup the regular hytech replica will be fine but can anyone post up a dyno comparison of the big tube header? Not to thread jack but I hate to make a thread on it when there is so many like this one
Bigger is not always better. On my old stock block and head ITR, I actually lost a great deal of torque where I needed it most. The test engine was a stock ITR motor with Skunk 2 Stage 2 cams, AEBS intake manifold, 70mm throttle body, AEM ITR CAI, stock cat back ( no cat). Tuned on Hondata.
You can see that the JDM ITR 4-1 header smoked the Hytech Big Tube header from 5,800 to 8,100 RPM. The Hytech made more peak power, but the car was slower. However, on my high compression 2 liter race motor, the Hytech worked very well. It comes down to selecting the parts that work well with the combination that you are running.
B19 I wouldn't expect to see a big tube header out perform something like the smaller header or a toda on a small 1.8 setup with just cams......you seem to be a pleather of information(no sarcasim intended) do you have a graph comparing the big tube on a 2.0 setup with say an smsp or rmf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch »</TD></TR><TR><TD CLASS="quote">B19 I wouldn't expect to see a big tube header out perform something like the smaller header or a toda on a small 1.8 setup with just cams......you seem to be a pleather of information(no sarcasim intended) do you have a graph comparing the big tube on a 2.0 setup with say an smsp or rmf?</TD></TR></TABLE>
92integraVTECgsr
29
Oct 20, 2008 12:30 PM
rick ef9
53
Jan 5, 2006 03:19 AM
