Headligts, Corner lights, Rear Brake lights flicker
Old Mar 3, 2008 | 07:45 PM
xalents23's Avatar
Default Headlights, Corner lights, Gauge cluster, Clock, Rear Brake lights flicker
Okay, I have a really anoying issue with my 1991 CRX SI. All of my lights in my car would flicker for a couple of seconds and go back to normal when I press the brakes. More like the lights go bright and then go dim on and on and on. Sometimes it would flicker and go away and come back. Even when the car is in motion all of the lights would flicker. Anyone have any solutions to this issue? Could it be my grounding wires? Any info or help would be appreciated.
Modified by xalents23 at 8:53 AM 3/4/2008
Old Mar 3, 2008 | 09:56 PM
patrickstar's Avatar
bump.
could it also be a dying battery?
Old Mar 3, 2008 | 11:12 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
Default Re: Headlights, Corner lights, Gauge cluster, Clock, Rear Brake lights flicker (xalents23)
i have the same problem in my 89 dx. it is the alternator because once you put a greater load on it, it reduces power to the other things.
i know my alt is only a 60amp and when my headlights are on and the fans kick on, the lights dim.
just get someone to rebuild it to about 100 to 120 amps and there would be no real problem. you could probably get it done for around 150 and a couple of hours.
especially if you have a system in your car or plan on adding one.
Old Mar 4, 2008 | 07:52 AM
xalents23's Avatar
Battery is fine and is new. I will check the alternator. Thanks for the info fellas.
Old Mar 4, 2008 | 07:57 AM
reydio's Avatar
Default Re: (xalents23)
Also check your grounds, some might have become corroded or not making good contacts with the body.
jdmkid8383
Nov 26, 2007 02:14 PM
Bikerxgames420
Sep 3, 2007 11:24 PM
nathchong
May 5, 2007 12:38 PM
