skunk2 tb failure DESTROYED my engine what can i do.........
Old Mar 3, 2008 | 07:30 PM
97ekb18b's Avatar
Default skunk2 tb failure DESTROYED my engine what can i do.........
one of the screws that holds the butterfly on in the tb came off sucked into my engine and destroyed the head and block............ do you think i have any kind of a chance of getting some kind of compensation........
Old Mar 3, 2008 | 07:32 PM
ke98248's Avatar
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (97ekb18b)
No -- not unless you got it professionally installed -- then the shop would be responsible. Skunk2 won't help you out, sorry..
Old Mar 3, 2008 | 07:33 PM
97ekb18b's Avatar
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (ke98248)
it wasnt installed professionally no, but still there product failed............
Old Mar 3, 2008 | 07:34 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">it wasnt installed professionally no, but still there product failed............</TD></TR></TABLE>
It can be blamed on improper installation. In fact, I'm willing to bet that was the cause.
Tighten everything, check twice. If you didn't do that, then it wasn't their fault.
Old Mar 3, 2008 | 07:38 PM
crazyguy's Avatar
u can call skunk2 company to find out and which reminds me to check on the screws on my skunk2 TB tomorrow morning
Old Mar 3, 2008 | 07:50 PM
97ekb18b's Avatar
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (crazyguy)
the thorottle body plate comes preinstalled, so why would i need to tighten or install it, the tb plate has 3 screws one came off sucked ito my engine and destroied the valves, valve seats and the piston........ it had absolutley nothing to do with the install.
Old Mar 3, 2008 | 07:56 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2 &raquo;</TD></TR><TR><TD CLASS="quote">Should any product(s) prove to be defective for any reason under any circumstance, the purchaser, and not the manufacturer, distributor, or retailer will assume financial responsibility for any consequential damages, repairs/service, and any other liability.</TD></TR></TABLE>
Pwnt.
Old Mar 3, 2008 | 07:57 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">the thorottle body plate comes preinstalled, so why would i need to tighten or install it, the tb plate has 3 screws one came off sucked ito my engine and destroied the valves, valve seats and the piston........ it had absolutley nothing to do with the install.</TD></TR></TABLE>
yeah .3 screws. and try to call skunk2 company and find out.
http://www.skunk2.com/contact.php
Old Mar 3, 2008 | 08:04 PM
97ekb18b's Avatar
yea i will give them a try because of all things to [freak]ing fail it shouldnt have been that damn screw.
Old Mar 3, 2008 | 08:06 PM
98vtec's Avatar
moderator emeritus
did you buy it new? from a dealer?
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">yea i will give them a try because of all things to [freak]ing fail it shouldnt have been that damn screw.</TD></TR></TABLE>
I think you missed something:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2 &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red"><FONT SIZE="6">Should any product(s) prove to be defective for any reason under any circumstance, the</FONT></FONT> <FONT COLOR="black"><FONT SIZE="6"><u>purchaser</u></FONT></FONT><FONT COLOR="red"><FONT SIZE="6">, and not the manufacturer, distributor, or retailer will assume financial responsibility for any consequential damages, repairs/service, and any other liability.</FONT></FONT></TD></TR></TABLE>
Old Mar 3, 2008 | 08:11 PM
BlueIntegraBoy's Avatar
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (Eran)
^^^ Wow, so if their cams snap in two places, it's not Skunk's fault.
95sloweg's Avatar
just give it a try tomorrow, it might or might not work. ERAN, you dont have to be a dick about it cause if it happened to you you would also try your best to blame the fault on skunk2.
97ekb18b's Avatar
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (98vtec)
i bought it new yes and i dont know if it was a dealer or not....
Old Mar 3, 2008 | 08:13 PM
97ekb18b's Avatar
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (95sloweg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sloweg &raquo;</TD></TR><TR><TD CLASS="quote">just give it a try tomorrow, it might or might not work. ERAN, you dont have to be a dick about it cause if it happened to you you would also try your best to blame the fault on skunk2.</TD></TR></TABLE>
im not trying to blame them entirelly but it did fail and it was on my daily driver i would never of expected the damn screw to come loose and destroy ****
Old Mar 3, 2008 | 08:14 PM
Eran's Avatar
HT White Ops
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">^^^ Wow, so if their cams snap in two places, it's not Skunk's fault. </TD></TR></TABLE>
Essentially. They don't have to shell out a dime for any of their products, and assume ZERO liability.
This is why I don't buy their products. Buyer beware.
Old Mar 3, 2008 | 08:15 PM
98vtec's Avatar
moderator emeritus
its simply to protect their business
if a cam breaks, how do you know it wasnt from over tightening the cam caps? or torquing in the wrong sequence? or not in steps? or trying to spin your new cool hip chipped ecu to 14000 rpm?
Old Mar 3, 2008 | 08:30 PM
suspendedHatch's Avatar
Yet people still buy their products... virtually everything in their entire lineup has had defects, then they release second and third versions of their products. Your sir, were a beta tester. Don't you feel special?
Skunk2 = Crap2
And everyone here including the administration will hush this up and come to Skunk2's defense.
You wont find that crap on my car.
Old Mar 3, 2008 | 08:36 PM
97ekb18b's Avatar
Default Re: skunk2 tb failure DESTROYED my engine what can i do......... (suspendedHatch)
all i have of there products on my car was this throttle body and front and rear camber kit, now im glad there going to be building me a ls/vtec haha
Old Mar 3, 2008 | 08:37 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">all i have of there products on my car was this throttle body and front and rear camber kit, now im glad there going to be building me a ls/vtec haha</TD></TR></TABLE>
They're not going to build you ****.
Old Mar 3, 2008 | 08:38 PM
I really like Skunk2 ***** though. One of the better ones I have tried.
Old Mar 3, 2008 | 08:44 PM
97ekb18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
They're not going to build you ****.</TD></TR></TABLE>
i was kidding dick lips, i think yo missed something the haha at the end.
Old Mar 3, 2008 | 08:48 PM
Eran's Avatar
HT White Ops
i was kidding dick lips, i think yo missed something the haha at the end.</TD></TR></TABLE>
I'm sorry I mistook your 'haha' of self-pity for a 'haha' of triumph?
Old Mar 3, 2008 | 08:54 PM
97ekb18b's Avatar
I'm sorry I mistook your 'haha' of self-pity for a 'haha' of triumph? </TD></TR></TABLE>
its no problem, im pissed but i already know they most likely wont do anything so im just going to laugh it off i guess.
Old Mar 3, 2008 | 09:05 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Yet people still buy their products... virtually everything in their entire lineup has had defects, then they release second and third versions of their products. Your sir, were a beta tester. Don't you feel special?
Skunk2 = Crap2
You wont find that crap on my car.</TD></TR></TABLE>
would you rather them not release new versions to fix the problem? personally, i cant stand people like you. Always blame the company and not the moron installing the product (not casting a label on the thread starter). **** happens that is beyond the companies control yet you want the world when 1 in a million motors blows up.....good grief.
He hasnt even contacted skunk2 yet and you are already bashing them.
I had a set of crower cams eat into my rocker arms. Should i blame crower? i think not. Why? because plenty of other people have ran them without any problems.
If he didnt buy the throttle from a skunk2 dealer, thats his fault. Who knows what really happened to the throttle after it left the assembly line?
there are too many variables as the case lies right now. not enough FACT. Just a bunch of people casting opinions on products they have likely never even tried.
opinion without experience is about as good as a blind seeing eye dog.
