Water Pipe all the same?
Old Mar 3, 2008 | 06:54 PM
dturbo's Avatar
Default Water Pipe all the same?
I'm looking to do an LS-V setup. I can get a hold of a bare b18a1 block. Only question I have is will the b16 water pipe/termo housing fit the b18a1 block?
Old Mar 3, 2008 | 07:16 PM
IN VTEC's Avatar
Default Re: Water Pipe all the same? (dturbo)
It'll fit, but you may have an extra port for the oil cooler coolant line.
Old Mar 5, 2008 | 05:50 PM
dturbo's Avatar
Default Re: Water Pipe all the same? (IN VTEC)
couldnt I swap the oil cooler over also?
Old Apr 22, 2008 | 02:04 AM
gsrcrazy's Avatar
wondering this also..i have all gsr accesories (including water pipe and oil sandwich cooler)... and im about to put a ls/v in it...
Old Apr 22, 2008 | 08:15 AM
all-mtr-teg's Avatar
Default Re: (gsrcrazy)
Yeah, you can swap over the oil cooler and water tube as long as you hook up all the hoses.
Old Apr 23, 2008 | 02:24 AM
gsrcrazy's Avatar
aaahh... found the answer...after observing and observing...
i personally cant use my "stock gsr" oil cooler on my B18A1
i put on my gsr water pipe...and i needed a place to hook up the last hose...
apperantly my ls block doesnt have this pipe fitting where that last hose would hook up to..
only 94-95 gsr's and all itr's came with that pipe fitting on the block...and i think some b16's...
heres the pic of a 94-95 gsr block (got it from yahoo images lol..)
heres a pic of the ls engine..with that fitting blocked off.. so no oil cooler for me...i'm going to use the ls water pipe... leaves me no choice...
Modified by gsrcrazy at 3:45 AM 4/23/2008
Old Apr 23, 2008 | 02:43 AM
gsrcrazy's Avatar
hmm...but to answer your specific question..
you can use the b16 water pipe and thermostat housing... but you cannot use the oil cooler... you're gonna come accross this exact problem..lol... just cancel the extra water exits on your water pipe.. the rest should bolt right up... :D
Modified by gsrcrazy at 1:05 PM 4/23/2008
Old Apr 24, 2008 | 03:00 PM
dturbo's Avatar
I'll probably end up tapping the block and throwing on a fitting. should work.
Ron Burgandy
Jul 13, 2014 10:29 AM
travis-b16a2-eg
Jun 22, 2007 08:32 PM
Timmay
12
May 17, 2007 05:14 PM
TwoKSiR
May 2, 2007 01:43 PM
riceball777
Jan 19, 2004 12:02 PM
