Instrument cluster
The OEM instrument cluster installed in my VP coupe desn't have a tachometer so i purchasd a 2004 Ex cluster to swap out. For insurace purposes and etc. I need to have the corect milage from my cluster on the Ex cluster. Is there any way to do this without paying a small fortune just to make things right?
I did the same but the EX tach that i got was american. My original had 61000km, the tach i got had 77000 miles...so now i have to convert how many miles I did from 77k to KM and add it to the original 61k km lol wheres my calculator.
I search the forum and came up with nothing but a how to on swapping and that the mileage is stored on the cluster. i want to transfer or adjust the mileage to the Ex cluster when i install it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vbkapousidis »</TD></TR><TR><TD CLASS="quote">I search the forum and came up with nothing but a how to on swapping and that the mileage is stored on the cluster. i want to transfer or adjust the mileage to the Ex cluster when i install it </TD></TR></TABLE>
You, personally, cannot adjust the mileage counter. It is something that a dealership will need to do for you. (It's stored in the cluster itself, and to modify the data, you need to edit the HEX code for the mileage, which is something you need Honda to do.)
As far as the cluster swap goes:
Cluster options- https://honda-tech.com/zerothread?id=2170717
Removal/Installation- https://honda-tech.com/zerothread/2204667
PS. You didn't search very well, because it took me merely 2 minutes to type this.
audio5050
Feb 14, 2007 07:22 PM
PhatBoy5015
30
Aug 17, 2006 11:19 AM
2000GSRT
Sep 4, 2004 08:11 AM
