B20b Swap into my 97 dx
I am going to put a b20b into my 97 dx
parts i have
JDM 20 motor with ls intake manifold
ls tranny and shift linkage.
20b timming mount
Si Left mount
My questions is what elso do I need?
what kind of ecu
what kind of harness jumper
what kind of starter
I did use the search button but only found info for pre 95 civics
Thank you for your help in advance
parts i have
20b timming mount
Si Left mount
what kind of ecu
Using the "search" feature would help you, but i'll give you a heads up. 1st off, its exactly the same as installing a LS motor (B18B).
You will also need a 99/00 Civic Si rear engine mount bracket, a integra throttle cable.
For my setup,i got and obdI harness conversion and run a PR4 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theworks001 »</TD></TR><TR><TD CLASS="quote">So any pre 94 integra shaft/ halfshaft will work??</TD></TR></TABLE>
no. i dont think da integra's halfshaft will work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">u will also need a b20 intermediate shaft/ halfshaft. 94 and up integra's wont work.</TD></TR></TABLE>
Gee, funny you'd say that....cause thats exactly what i'm running and it works fine, so thats not true. You do know that externally, both a B18B and a B20B are "identical"
Even internally, they use the same crankshaft and rods....the only difference is piston size (81mm vs 84mm)
Here's an engine shot of my swap
yup i got a b20 im my 96 coupe and im running a ls intermidate shaft and axles....almost everything is ls and as far as the mounts go the only thing i had to change was the driver side mount piece that is bolted to the block with those two bolts that are pointed at the top the b20 one made my motor gangster lean on that side it sat hecka low, i just got a ls one.....good luck and enjoy the wheel hop
So the b20 mounts work but the one thats on the drivers side right? you just got an LS mount for that side correct also where if you have any parts for sale get at me I live in the bay too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">
nice
</TD></TR></TABLE>nice
yeah the driver side, not the cylinder shaped mount with the rubber on top but the bracket that mounts to the block, i dont really have anything usefull i could sale you cause everything i have is stuff your probably gonna take off......oh yeah you will have to get a ls intake manifold,throttle body, fuel rail i got mine at a local parts yard for like 55 for everything.....
so the rear SI mount is not needed?
let me see if I got everything correct crv rear mount, crv transmision mount and Ls driver side mount.
Also they are the brackets not the round ones with rubber right
thanks
thanks
yeah the driver side is, its the mounting bracket not the mount, and for the rear mount yeah a si one should be ok cuase its for a civic coupe with a b series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">Using the "search" feature would help you, but i'll give you a heads up. 1st off, its exactly the same as installing a LS motor (B18B).
For my setup,i got and obdI harness conversion and run a PR4 ecu.</TD></TR></TABLE>
i did not change my throttle cable, but i did mod the cable bracket.
yeah it will hit the hood........but i was gonna try proping the hood up in the rear like people do with washers to see if it will fit cause b20 TB is bigger i think....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theworks001 »</TD></TR><TR><TD CLASS="quote">From what I've heard you cant use the intake manifold because its too high and will hit the hood but correct me if I'm wrong as this would be helpful</TD></TR></TABLE>
omg....the pic i posted "is" the original intake manifold, obviously it fits just fine. Now its true that the 1st couple years of the B20B had the high rise manifold, that had to be swapped for an LS model, but thats a piece of cake and can be had dirt cheap at the junk yard.
either way the orginal posted mention he is getting a LS IM, and im running a GSR intermediate shaft myself with no issues. also.. i would suggest a better trans.. LS trans will make the b20 slow and sluggish
i have a obd1 jumper harness and a pr4 ecu with a dif map.
that ls trans is gonna leave you dissapointed. i had one at first then got a gsr. now im using a b16 tranny and wouldn't go back. unless you plan on going turbo and using a small turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! »</TD></TR><TR><TD CLASS="quote">
that ls trans is gonna leave you dissapointed. </TD></TR></TABLE>
I dissagree. 1st off, different years of tranny's have different ratio's. I'm running a 1999 LS tranny, which has better gearing than say one found in a 1995 model. My car goes like hell. I have serious traction issues already in 1st, i could only imagine how it would be worse with a b16a gearbox. At any speed in 1st gear, i can step on it, just with the throttle an start burning out, i would not consider the LS tranny to be a bad choice.
