code 16
Old Mar 3, 2008 | 04:07 PM
westside49block's Avatar
Default code 16
i have a 1991 civic hatch. i dont know the engine but im getting a code 16 and at start up it doesnt want to run and it smells like alot of gas and about a minute of running like its miss firing it goes to normal and it only happens at start up
Old Mar 3, 2008 | 07:04 PM
zcmotor's Avatar
Default Re: code 16 (westside49block)
check your injector try cleaning them and put them back, or one should be bad. and also check to see if they are plugged in good. Mine did the same thing minutes ago and i just fixed it.
Modified by zcmotor at 8:24 PM 3/3/2008
Old Mar 3, 2008 | 07:09 PM
Default Re: code 16 (zcmotor)
its not the engine with 4 injectors i dont even see an injector. it looks like a carburator but it says pgm-fi on it still, im confused and if it does have injectors where would they be located?
Old Mar 3, 2008 | 07:11 PM
sorry i just looked up a d15 engine and it looks the same as mine if it makes a difference
Old Mar 3, 2008 | 07:14 PM
90sedan's Avatar
Sounds like a service manual would help you the best.
Click the link and download the one for the 88-91 civic. You will find everything you need to know, there's even a section that helps troubleshooting ecu codes.
http://hondatech.info/downloads/Auto/Manuals/Civic
Old Mar 3, 2008 | 07:18 PM
Default Re: code 16 (90sedan)
could it be a main relay going out? when i start the engine it runs rough and it sounds like a subaru engine if that helps with the sound, but about 1 or 2 minutes later it smooths out and runs normal untill i turn it off and start it back up. and im trying to save money by using the computer instead of buying a manual
Old Mar 3, 2008 | 07:27 PM
zcmotor's Avatar
you have the DPFI check the plugs that are green. clean them or disconnect one and turn the engine on and see if it gets better.
Old Mar 3, 2008 | 07:30 PM
oh ok thanks ill check it in the mornig and write back with the resaults
Old Mar 3, 2008 | 07:37 PM
90sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by westside49block &raquo;</TD></TR><TR><TD CLASS="quote">could it be a main relay going out? when i start the engine it runs rough and it sounds like a subaru engine if that helps with the sound, but about 1 or 2 minutes later it smooths out and runs normal untill i turn it off and start it back up. and im trying to save money by using the computer instead of buying a manual</TD></TR></TABLE>
I gave you a link for a free download.
Old Mar 3, 2008 | 07:41 PM
oh my bad thanks i guess i should read the message more carefully. thanks again
CRX-CHACE
12
Jul 3, 2013 07:40 PM
red91hatch
Jun 6, 2008 06:23 AM
SupraRXZ
Apr 6, 2006 09:48 AM
b16awarrior
Jan 23, 2003 11:48 AM
