Crashed my EG... What part is this????
Old Mar 3, 2008 | 03:08 PM
Eg4Kory's Avatar
Default Crashed my EG... What part is this????
I just crashed my 1993 civic eg. What is this part called? I want to know if it is easier to just buy this whole part then to straighten it out. (obviously on a diff car, but this is the piece)
Old Mar 3, 2008 | 03:09 PM
z6hatchboy's Avatar
Default Re: Crashed my EG... What part is this???? (Eg4Kory)
Upper radiator support?
Old Mar 3, 2008 | 03:12 PM
Relic1's Avatar
Default Re: Crashed my EG... What part is this???? (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Upper radiator support?</TD></TR></TABLE>
search on here, replacing it is not as easy as a few bolts, but it's very possible to do. Typically replaced as a whole, not just the upper/middle/lower portions.
Old Mar 3, 2008 | 03:30 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg4Kory &raquo;</TD></TR><TR><TD CLASS="quote">I want to know if it is easier to just buy this whole part then to straighten it out.</TD></TR></TABLE>
Yes, if you have a spot weld drill bit, a welder, and rosette welding skills.
Old Mar 3, 2008 | 04:22 PM
gizzerhatch's Avatar
crossmember: replace it. it is not worth the work to bend it back to place and it wouldn't be as strong.
Old Mar 3, 2008 | 04:24 PM
ke98248's Avatar
Default Re: Crashed my EG... What part is this???? (gizzerhatch)
The upper radiator support is spot welded in most places and you may need to take the car to an alignment car measurement system to check for out of alignment on the car's frame, strut towers, etc...
Old Mar 4, 2008 | 04:47 AM
EJ7CoUpE's Avatar
Default Re: Crashed my EG... What part is this???? (ke98248)
Certifit ftw
Old Mar 4, 2008 | 06:23 AM
egmatt93's Avatar
Default Re: Crashed my EG... What part is this???? (EJ7CoUpE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ7CoUpE &raquo;</TD></TR><TR><TD CLASS="quote">Certifit ftw</TD></TR></TABLE> haha for sure 75$ for a whole rad support, drill out the factory points( not sure what there called) they look like circular indents, after there drilled out then u have the pull off the old one, then when ur re installing it use and 4 bumper support bolts to hold it in place. then ull need to pairs of vise grips to clamp at the top corners where the fender sits, make sure u line up the holes before u clamp em in place, then just throw some tack welds on it and re assemble, me n my cousin have done it too many times haha
Old Mar 4, 2008 | 06:48 AM
Tomm R's Avatar
Default Re: Crashed my EG... What part is this???? (egmatt93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Yes, if you have a spot weld drill bit, a welder, and rosette welding skills. </TD></TR></TABLE>
I wounldnt say you need rosette welding skills. I replaced mine due to the previous owner straightening it out very badly and replaced it myself with no trouble at all, get yourself a spot weld drill peice ( it is possible with just a drill bit but it is a lot easier with the correct bit).
Just get practicing with the welder on a sheet of metal, this is how i learnt and i havent had any problems with my welds!
Good luck with it!
turbohf
Northwest (Sales)
Jun 20, 2008 08:04 PM
CRX30436
Jan 21, 2008 05:09 PM
Realek4
Mar 26, 2007 07:49 PM
spintboy
Dec 24, 2006 08:54 AM
Hater-Trend
20
Jan 24, 2005 09:43 AM
