How to lock the balance shafts and to remove them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">How do you guys lock the balance shaft gears in place to remove those 12mm nuts?</TD></TR></TABLE>
bump for info
bump for info
i know on the shaft on the rear of the block there is a 12mm bolt you can take out and insert something to lock it then remove the bolt. as for the front, im not totaly sure.
dleccord
Jan 10, 2010 03:35 PM
yh23
Feb 18, 2007 12:13 PM
Dai_Ca_Vietnam_H22a4
Feb 9, 2006 02:09 PM
