What exhaust do i use?
ok so i dropped in a ls in the del sol....i was wondering what aftermarket exhaust do i use...everything i find is for the damn single cam...
will an eg exhaust fit? if so coupe or hatch
Get an aftermarket exhaust for your Del Sol -- you may need a bit of fab work done at an exhaust shop to get the header to connect to the cat-converter though.. 2.25 or 2.5 inch is plenty.
the stock del sol intermediate pipe is good enough for n/a set up. u can use oem honda s2000 axle back, itr, 07 civic si, dc5 integra/rsx ...etc axle back and have a muffler shop cut and welded for you, caz u need to cut,extended and welded the cat converter anyway. so get it done at one time.
