skunk2 front camber kit fitment... any modification needed?
Ok so last month, or so I thought I would throw together a cheap suspension setup. Well was that a bad idea. I went out and bought some eBay coil-overs, and the rhino adjustable front camber kit. So for the record the rhinos you have to shave approximately 1/8 off the sides of the arms for clearance issues in the shock tower. I want to know if I order the skunk2’s if I will have the same issue.
http://cgi.ebay.com/ebaymotors...50376
so if these will fit with no grinding or shaving, and fit like they are suppose to my setup will be fairly ok.
skunk2 springs
agx adjustable shocks
and the skunk2 front cambers if they work.
skunk2 springs
I kept them intact. I didn't know if they had a structural benefit, so I left them. Kind of made it a pain to tighten the bolts back down, but they are only 22ft.lbs, so it's not too difficult to manage.
