Compression test results. Input appreciated!
Old Mar 3, 2008 | 11:46 AM
Convert's Avatar
Default Compression test results. Input appreciated!
Motor is a JDM B16A. no clue what the mileage is.
#1 150
#2 180
#3 175
#4 175
This was after a chemical cleaning at a shop. any input as to how these numbers fair would be appreciated. internals are completely stock.
thanks~
Old Mar 3, 2008 | 12:00 PM
crazyguy's Avatar
Default Re: Compression test results. Input appreciated! (Convert)
it is kind of low to me, when i did compression on my jdm sir2 b16a engine (10.4:1 compression ratio).
i got 242~248 all across.
* 8:1-8.5:1 compression: 150-170 psi per cylinder
* 8.5:1~9.5:1 compression: 170-210 psi per cylinder
* 9.5:1~11:1 compression: 210-275 psi per cylinder
* 11:1+ compression: 250+ per cylinder
Old Jan 28, 2009 | 03:37 PM
lexluther's Avatar
I had a few civics that had 210psi, one, i think was a 1990 dx, and the other was a 1993 vtec, that had 210, is 180psi on my 1998 lx good! My car seems weak and according to that chart above, my 9.4:1 should have 170-210... so is 180 the low end of the spectrum! I know it only has 106hp but its a squeeker.
Old Jan 28, 2009 | 04:02 PM
0ne-Cam's Avatar
Im assuming thats a dry compression test? Do a wet (pour some oil into each cylinder) and see if the numbers change. At the end adjust your valves, by doing this there should be some change in the compression, if not theres something wrong with the valves, cylinder rings, or the sleeves.
Old Jan 28, 2009 | 05:44 PM
lexluther's Avatar
I already checked the valve adjustment, if my rings are bad, all my cylinders have within a couple psi of each other 180psi... i am wondering if my timing belt may have stretched, it says "honda" is this possible, if the belt is off some, it will effect all cylinders evenly.. i have a new on i am gonna put as soon as the weather permits.
Brandon Peters
Oct 18, 2015 05:37 PM
88 civic
Apr 5, 2009 03:21 PM
barren25992
Mar 19, 2008 06:04 AM
lucidvtec
May 30, 2006 03:47 PM
Z32Z06
Honda S2000
Feb 8, 2006 04:59 PM
