Turn signal's dont work?
wassup fella's, gotta 93 integra, for some reason my turn signals dont work...has no power or anything going to it, i checked the fuses and it's fine, check the wires..fine..my hazard's and horn still works, i was wondering can the relay go bad just for the turn signals or there's another source causing this problem? the part number for the relay is 38300-SE3-013 (MITSUBA FR-3309) thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveteggy92 »</TD></TR><TR><TD CLASS="quote">I'm not sure if this holds true with hondas but from my experience the relay on most cars usually always goes out at some point, not all that uncommon.</TD></TR></TABLE>
But can it only effect the turn signals and not the hazard's and horn? Because dont they all run on the same relay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">haha good point^^</TD></TR></TABLE>
lol duh. i would think that would be the first thing to check....but i guess bulbs never burn out...
nah bulbs are good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n.o.r.e »</TD></TR><TR><TD CLASS="quote">has no power or anything going to it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">relays can also be faulty...i don't even know where the one you are talking about is even located on your car</TD></TR></TABLE>
Follow the arm wires to the relay under the dash.
to refresh what i mean about no power, when i move the arm up and down the green turn arrows dont light up..but when the hazard's come on the green arrow's light up fine o_0
what about the actual turn signal switch on the steering column. I've never had the problem on a honda but my blazer broke. The hazards would work but the turn signals wouldn't work.
I was just gonna say the same thing...
Try to replace the actualy turn signal arm that you move to activate the signals...if it's nothing else, there's a very good chance that it can be that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denraweb »</TD></TR><TR><TD CLASS="quote">I was just gonna say the same thing...
Try to replace the actualy turn signal arm that you move to activate the signals...if it's nothing else, there's a very good chance that it can be that.</TD></TR></TABLE>
well i tried 1 other one and still the same, but i dont know if that one was bad aswell...but i'll try that next thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 »</TD></TR><TR><TD CLASS="quote">ur plug that goes into the hazard button may have come loose. this happened to me and none of the turn signals worked but the hazards did..</TD></TR></TABLE>
what you mean? the plug that connect's behind the hazard switch or one of the wire's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 »</TD></TR><TR><TD CLASS="quote">your hazard button has a plug w/ wires attached to it..make sure it is plugged in tightly or ur turn signals will not work</TD></TR></TABLE>
hmm really, thanks for the info..it was kinda not fitting in right, i'll be sure to try that, thanks!
Yeah my side lights dont work, neither side, but m fronts flash. The sides Ive learned flash after the front lights, I've taken both bulbs out and sake em, they both sound good, but obviously dead, unless Im facing whatever you are. But yeah I'd suggest changing the lights even if they dont sound bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpicKills »</TD></TR><TR><TD CLASS="quote">Yeah my side lights dont work, neither side, but m fronts flash. The sides Ive learned flash after the front lights, I've taken both bulbs out and sake em, they both sound good, but obviously dead, unless Im facing whatever you are. But yeah I'd suggest changing the lights even if they dont sound bad.</TD></TR></TABLE>
well if it was the bulbs wouldnt the green arrow's still blink just a little more constant?
hmm really, thanks for the info..it was kinda not fitting in right, i'll be sure to try that, thanks!</TD></TR></TABLE>
yeah than that could most likely be your problem
let me know
let me know
