Something leaking out of car, please help find out what it is...
There is a clear, odorless liquid that is coming out of my car. It has a consistency, so it isnt water. It look like it is coming below the intake manifold somewhere. I went under, and the whole underside of the car is slimey, probably from the wind pushing the liquid back. ANyone know what it is?
I doubt it's PS fluid, since it isn't really clear and it definately has a distinctive odor. Unfortunately, I don't have any other suggestions as to what it might be. Quite a stumper.
Humm maybe you ran over something? try to clean it off, maybe steam clean it and see if you can locate where it is comming from after you cleaned it off.
[Modified by ChargedSi99, 8:10 PM 7/6/2002]
When this stuff leaked out, did you have the a/c on for quite some time?
If so, it's just condensation from the a/c coming out of the drain hose. The a/c evaporator drain hose is by the passenger side wheel well.
[Modified by Tommy_Gunns, 2:34 PM 7/7/2002]
Possibly coolant mixed with road debris?
There are coolant lines on the back side of the intake manifold...
Jason
Jason
my money is with Tommy...
with the a/c on you'll dump quite a bit of watery fluid...and crap can mix in with it (like grease).
I have seen ps fluid that is clear.......
CARMA_626
Aug 2, 2007 07:30 AM
94c1v1cex
May 21, 2007 05:03 PM
