New oil
Old Mar 3, 2008 | 07:43 AM
citrus3000psi's Avatar
Default New oil
With so many oil consuming ITR maybe we should help the envrioment.
http://www.smokelessoil.com/NewWebsite/index.php
lol im not trying it. But they say it helps even with oil consumption.
Old Mar 3, 2008 | 08:21 AM
get RIGHT's Avatar
Default Re: New oil (citrus3000psi)
Who is gonna be the Guinea Pig?
Old Mar 3, 2008 | 08:24 AM
Ed 341's Avatar
I'm sure the makers never even thought about 8400RPM+.
Old Mar 3, 2008 | 07:42 PM
typeR#0427's Avatar
*quote*
Will my engine start smoking again if I start using regular oil again?
Yes; ENTEK Smokeless Motor Oil does not smoke, however, it will not repair a worn out engine.
*quote*
ll my engine continue to burn oil?
ENTEK Smokeless Oil is formulated to retard oil burn off as well as slow or stop small leaks; however, if you engine had a high consumption prior to the use of ENTEK Smokeless Motor Oil, it will probably continue to use oil, howbeit, at a muc
so does this mean your motor still "burns" oil, you just cant see the smoke?
<--who is somewhat confused
Old Mar 3, 2008 | 08:07 PM
Casey's Avatar
Default Re: New oil (typeR#0427)
id give it a shot if it wasnt a million dollarz
SathheshG
May 27, 2017 03:47 PM
globy123
12
Oct 18, 2009 03:01 PM
bOOsT-FeIn
Apr 5, 2007 04:50 PM
