My temp guage goes down while I accelerate, any help?
Is this the stock gauge, or an aftermarket?
I'm thinking some type of voltage drop.
I see you've got another post about a fluid leak ... so, I don't really know.
[Modified by Zygspeed, 10:47 PM 7/6/2002]
Its the stock guage. Its the wierdest thing, can it be do to a leak I have? I am stuped, anyone have any suggestions? Ryan
Could be low on coolant as well...nah low on coolant would heat the motor
You're right, I read the original post wrong. Thought he meant that the temp was going up and when accelerating go back to normal. Don't mind me, I'm stupid
i misread sometimes too
Let me see if I remember thermistor temperature sensors right off the top of my head. Cold they have high resistance.....like 5 K or so, hot some drop to about 150 Ohms. So if the gauge goes low temperature , it looks like high resistance on the sensor side of the circuit. ....> perhaps an open circuit to the sensor.
Under acceleration your engine is torqueing over a bit and things are moving around. I would give a look at the connectors and wiring to the temperature sensor, even right at the sensor. Look for something that may be going open when the engine moves a bit. Wiggle those wires as someone looks at the temp gauge.
Good luck,
Regards,
BigMoose
Good luck,
Regards,
BigMoose
Charlie Moua
Dec 29, 2002 05:25 PM
accel, accelerate, accelerating, accerlerate, car, cars, drop, drops, engine, gage, gauge, high, hot, temp, temperature, temps, type
