built ls vtec vs stock ls turbo
Old Mar 3, 2008 | 07:40 AM
b18 hatch mike's Avatar
Default built ls vtec vs stock ls turbo
witch one do you guys think would be better
Old Mar 3, 2008 | 08:02 AM
b19coupe's Avatar
Punt!
Old Mar 3, 2008 | 08:13 AM
Default Re: built ls vtec vs stock ls turbo (b18 hatch mike)
come on guys a stock ls-t vs a buit ls vtec all motor
Old Mar 3, 2008 | 08:37 AM
racebucket_eg's Avatar
This is a matter of opinion, do research and make your choice.
Old Mar 3, 2008 | 10:01 AM
b19coupe's Avatar
It completely depends on the setup.
A stock LS block with a stock B16 head, stock cams, stock exhaust etc. on pump gas vs a sleeved built LS motor with a ported head, GT35R , 3" downpipe and 3" exhaust running C16 and 25 lbs. of boost--the boosted motor might have a slight advantage.
A sleeved/stroked properly built LS block with a very good ported B16/GSR head, Pro 2 cams, SMSP header and 2 1/2 " exhaust vs a stock block LS with a Greddy kit at 6 lbs. on pump gas through the stock exhaust with cat, the LS/VTEC may possibly, perhaps have a very slight edge
Old Mar 3, 2008 | 10:39 AM
b19coupe's Avatar
Example:
The turbo motor makes 27 ft-lbs more peak torque, but the LS/VTEC sustains more torque at higher RPM to end up making 46 HP more.
Every engine combination is different, the question is too generic for a conclusive answer.
Old Mar 3, 2008 | 12:57 PM
Default Re: built ls vtec vs stock ls turbo (b19coupe)
i think i am going to do ls turbo then build the block and slap my built ls-vtec head on it
silverdc2integra
Sep 28, 2009 11:17 AM
fullracecrxsi87
Oct 21, 2005 10:36 AM
redlseg
Jun 24, 2005 06:43 PM
red_hatchback
13
Jun 8, 2005 07:59 AM
nighthunt6
11
Feb 10, 2002 08:40 PM
