all motor
Old Mar 3, 2008 | 06:37 AM
zdalunatic's Avatar
Default all motor
I have a 99 si im lookin to make atleast 200WHP! Rite now i have a semi built b16 in there! With the B16 i have CTR piston, eagle rods, acl bearing, S2 intake manifold, 70MM TB, LSD trans, Clutchmasters stage 2 clutch, catbak exhaust! But im done buildin that! I picked up a JDM GSR block with no pistons n i wanna make 200 WHP! Im goin to use my B16 head with a 5 angle valve job, inline pro vavles, valve springs n retainers, Skunk2 Stage 2 pro series cams, n AEM Cam Gears..i have everything for my head plus a Hy-tech header, AEM feul pressur regulator, rc 450 injectors, 255 whalbro fuel pump n mayb some more juss chillin at the crib! Wat should i do to the block?
Old Mar 3, 2008 | 07:04 AM
jdmhondas's Avatar
Default Re: all motor (zdalunatic)
sleeve it and put a turbo on that unit!!!!!
Old Mar 3, 2008 | 07:05 AM
2redstars's Avatar
high compression pistons, and then get it tuned.
Old Mar 3, 2008 | 07:10 AM
jdmhondas's Avatar
Default Re: (2redstars)
yep def pistons and tune
Old Mar 3, 2008 | 11:27 AM
zdalunatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars &raquo;</TD></TR><TR><TD CLASS="quote">high compression pistons, and then get it tuned.</TD></TR></TABLE>
should i put 12.5-1 compression or 11.5-1! n wat kind of rods do u perfer?
im stayin NA, my bad for not tellin yall earlier
JerzyFin3zt
14
Jun 25, 2013 05:18 AM
DC2-ProdUcTiOnS
14
Mar 15, 2009 03:43 PM
kaptr1d
349
Apr 1, 2006 09:10 AM
nonoy93cvc
11
Oct 8, 2005 09:08 AM
