i have no brakes
finally got my crx running good, and low and behold still can drive it, i dont have any brakes, theres brake fluid, i have bled them, and no leaks, when i press them in it pushes air out of my throttle body, i dont think thats normal, someone please help!!!
I think you mean master cylinder instead of throttle body.
If you are seeing air in the M/C you may need to get a new one if you can't build up any pressure. If you are hearing air when you press on the brakes you need to replace your booster.
It sounds like you need to try and bleed the system again.
Did you take the brake system apart in anyway?
Do you have pressure in your brake pedal?
The air coming out of the throttle body is caused by the brake booster diaphram pushing air back into the intake manifold.
white90crxhf
21
Aug 9, 2006 10:07 AM
