Jun Camgears...
Old Jul 6, 2002 | 05:35 PM
AllMotorITR's Avatar
New User
Default Jun Camgears...
Does anybody have information and/or pictures of these camgears? I plan on going with a Jun head, and I have heard that is it not recommended to mix and match cams and camgears: Does it really matter? How do these camgears differ from Toda?
Thanks in advance for the information!
Chris
Old Jul 6, 2002 | 06:51 PM
New User
Default Re: Jun Camgears... (1 FAST R)
Nobody is using these?
Old Jul 6, 2002 | 06:54 PM
StinkyTofu's Avatar
PM Canuck-mx6, i believe he is using the full jun head package
Old Jul 6, 2002 | 07:12 PM
koy's Avatar
koy
New User
Default Re: Jun Camgears... (StinkyTofu)
Old Jul 6, 2002 | 07:44 PM
K1R's Avatar
K1R
Jun gear spec +14/-14 deg.
[Modified by Torque, 4:45 AM 7/7/2002]
Old Jul 6, 2002 | 07:57 PM
New User
Default Re: Jun Camgears... (Torque)
ATTN: Jun 3 Cam owners
What camgears are you using?
Old Jul 6, 2002 | 08:17 PM
Cheap Bastard's Avatar
New User
Unorthodox Racing Cam Gears.
Old Jul 6, 2002 | 08:44 PM
azn98R's Avatar
Default Re: Jun Camgears... (Cheap Bastard)
I'm using the JUN cam's, valve train, and gears .... what is that you wanted to know again?
Old Jul 6, 2002 | 08:46 PM
New User
Default Re: Jun Camgears... (azn98R)
i just wanted to know who was using them, and if i can use jun cams and toda gears
Old Jul 6, 2002 | 09:02 PM
New User
yes, you may.
Old Jul 6, 2002 | 09:07 PM
mafay2's Avatar
New User
why not?
but if something bad ever happen to your JUN cams, don't expect JUN will do anything about it!!
Old Jul 7, 2002 | 12:20 AM
1 2 NV's Avatar
those gears pictured look like JUN gears for nissans. they r pretty plain, look identical to pic, just dont have the 5 holes around the center cam hole. and only have 4 bolts.
Old Jul 7, 2002 | 01:01 AM
GokuSSJ4's Avatar
Default Re: Jun Camgears... (mafay2)
why not?
why would they blame it on the cam gears ?.
[Modified by Spoon1, 10:01 AM 7/7/2002]
Old Jul 7, 2002 | 01:26 AM
SuperTwinz's Avatar
Old Jul 7, 2002 | 01:45 AM
mafay2's Avatar
New User
Default Re: Jun Camgears... (Spoon1)
why not?
They will probably blame it on the cam gear and say that JUN cams are design to work with JUN cam gears only.
Old Jul 7, 2002 | 01:56 AM
StinkyTofu's Avatar
You'll be pretty damn lucky if you can get jun to warrant your stuff even if you're using their complete head. There are too many variables involved in the installation. Jun can't monitor each installation and will most likely blame the installation error.
Old Jul 7, 2002 | 03:58 AM
YelLowITR's Avatar
i don't think it's matter with different cam gears, as long as it's 4 bolt so it won't slip, and i'm running spoon cam gears with JUN head...
Old Jul 7, 2002 | 05:48 AM
canuck-mx6's Avatar
Chris
There ya go
Old Jul 7, 2002 | 06:33 AM
slowerthanu's Avatar
New User
Default Re: Jun Camgears... (canuck-mx6)
I was using JUN cam gears, but I made my own out of balsa wood (lightweight) and now my car wont run
Old Jul 7, 2002 | 07:06 AM
SIINSI's Avatar
Default Re: Jun Camgears... (slowerthanu)
Old Jul 7, 2002 | 07:11 AM
canuck-mx6's Avatar
Default Re: Jun Camgears... (JUNIFIED)
The only bad thing is that each tick is 4 degrees.....that is too far apart for fine tuning IMO
Old Jul 7, 2002 | 07:12 AM
canuck-mx6's Avatar
BTW, why does it look like you are off a tooth? Your red lines are not parallel to each other, and your horizontal lines do not line up
[Modified by canuck-mx6, 4:14 PM 7/7/2002]
Old Jul 7, 2002 | 08:17 AM
SIINSI's Avatar
That pic was taken, mid-installation
Miguel
Old Jul 7, 2002 | 10:01 AM
1 2 NV's Avatar
what kinda car r u runnin JUNIFIED?
Old Jul 7, 2002 | 10:16 AM
SuperTwinz's Avatar
Default Re: Jun Camgears... (hondaatwsu)
lol
