car wont start dont know what wrong, HELP!
Old Mar 2, 2008 | 04:00 PM
topREV's Avatar
Default car wont start dont know what wrong, HELP!
okay, here the story, i let my bro drive my car to practice driving stick shift, after he kill it a couple time, then the last time he kill it, it wont start, i jump the car with a jumper cable that night it start up, next day i turn the car on, it wont start, at first i thought it might be the battery, but i use a battery from my other eg and it cant start ether, when i turn the key in the ignition, the light in the cluster come on, like the battery light, end brake light, etc., but when i turn it to start it, it wont start and it doesnt make any noise, i just change the starter today, it still didnt work, i pretty sure is not the battery in my other eg, not sure if is the alternator, but its workin fine, anybody know what wrong with my car, its a 94 hatch dx stock motor....HELP ME PLEASE!!!
Old Mar 2, 2008 | 04:03 PM
crazyguy's Avatar
Default Re: car wont start dont know what wrong, HELP! (topREV)
try to check all the fuses. and also main relay. does fuel pump prime?
Old Mar 2, 2008 | 04:04 PM
chuisek9's Avatar
is it getting fuel?check to see if the distributor is sending spark!
Old Mar 2, 2008 | 04:12 PM
suno's Avatar
Check fuses!
Old Mar 2, 2008 | 05:31 PM
topREV's Avatar
well i did a push jump, and pop the clutch, and its start up, and the fuse under the hood is fine, im going to check the rest of the fuse under driver side
Old Mar 3, 2008 | 07:41 PM
topREV's Avatar
HELP!!! i cant figure it out, i check all the fuse its not blown, what can it be, or am i just missing some thing, when i turn the key it make a click in the fuse box under the hood, anybody know what wrong with my car
Old Mar 3, 2008 | 07:56 PM
Former User's Avatar
Default Re: (topREV)
You may have a bad Starter Cut Relay:
Old Mar 3, 2008 | 08:28 PM
topREV's Avatar
thanks man ill try that....see if it work, cross my figure, and for the rest of the other HT peeps, thanks man, im like hella stress out on this....im a noob on car work
Old Mar 3, 2008 | 08:52 PM
99GreenEX's Avatar
* B A N N E D *
Mine used to do that, the problem was the cround.. i shaved down the grounding bolt spot, cleaned the terminals, and baught a thick *** ground cable, put that on and no more issues...
I bet after it clicks dead, that you can go wiggle or shake your ground cable, get back in the car, and everything will power on...
Old Mar 5, 2008 | 05:47 PM
topREV's Avatar
Default Re: (RonJ@HT)
hey where exactly the starter cut relay, like what color, what next to it, if you could can you provide picture, im not sure how it look like, thanks very much...
Old Mar 5, 2008 | 05:51 PM
topREV's Avatar
Default Re: (99GreenEX)
i dont think is the grounding cable, cause i got power to the car, just that it wont start...
Old Mar 5, 2008 | 06:09 PM
Juan_Mitosis's Avatar
I've seen a similiar issue like this, with one of the cables that goes to the starter, becoming unplugged. And you can barely tell because it has a rubber cover around it. Theres' 2 cables, the thick one coming from the battery, and the thin one I assume comes from the ignition switch. THIS is the one I pushed back in, and tightened. Check it out.
Old Mar 5, 2008 | 06:31 PM
xXCarfreakXx's Avatar
Clutch switch?
Old Mar 5, 2008 | 09:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topREV &raquo;</TD></TR><TR><TD CLASS="quote">hey where exactly the starter cut relay, like what color, what next to it, if you could can you provide picture, im not sure how it look like, thanks very much...</TD></TR></TABLE>
Old Mar 11, 2008 | 01:54 PM
dewdiligence's Avatar
Default Re: (xXCarfreakXx)
Hey - I had the EXACT same symptoms.. and checked the small cable that goes to the starter post too. It was loose. Plugged it back in, and the car started right up!
Old Mar 11, 2008 | 06:17 PM
topREV's Avatar
Default Re: (dewdiligence)
i just change the starter, and plug the two wire in, and i my old one was still good....
Old Mar 11, 2008 | 06:27 PM
topREV's Avatar
okay i took out the bottom part of the dash and the metal pease and i can only find one of the fuse, i think cause i dont have moonroof, so will the moonroof relay still be there or not, anywase i found one relay but it look like the power window relay, than again i dont have power window, so is that it im not sure......and i cant even get it out, if any body know the part number to it, that be geart, cause the lady at dealership didnt understand what it is...anywase any ideas
Old Mar 11, 2008 | 06:47 PM
92_b20_eg's Avatar
before your car pooped on you.....did it ever randomly have issues on starting
Old Mar 11, 2008 | 06:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topREV &raquo;</TD></TR><TR><TD CLASS="quote">okay i took out the bottom part of the dash and the metal pease and i can only find one of the fuse, i think cause i dont have moonroof, so will the moonroof relay still be there or not, anywase i found one relay but it look like the power window relay, than again i dont have power window, so is that it im not sure......and i cant even get it out, if any body know the part number to it, that be geart, cause the lady at dealership didnt understand what it is...anywase any ideas</TD></TR></TABLE>
The starter cut relay is shown in the lower right side of the bottom picture that I posted. Note the slight differences from the power window relay (also shown in picture). Additionally note that, after you remove the relay, the picture also details how to test the relay so that a good relay is not replaced unnecessarily. The relay tests require a continuity tester and a battery power source.
Old Mar 12, 2008 | 05:57 PM
topREV's Avatar
Default Re: car wont start dont know what wrong, HELP! (92_b20_eg)
nope the car never have problem starting that bad
Old Mar 12, 2008 | 06:01 PM
topREV's Avatar
hey, i found the starter cut relay, the weird part is that it look like the abs relay, cause the i look at the horn relay, its different from the from the starter cut relay that weird, cause i dont have abs, hmm, then again im just giong to get the one that look like the horn relay with i cant find anywhere, only the dealership have it and i have to order too, plus is like $52 bucks...thanks guys
Old Mar 25, 2008 | 07:20 PM
topREV's Avatar
okay my HT people, okay change the starter relay and put in a new battery, guess what, it still doesnt start, now im clueless anybody got any suggestion what im should do???....if not than im probably take it to the shop...
Old Mar 25, 2008 | 07:53 PM
joshluis's Avatar
i had a similar problem on my eg and it was the engine had no ground..dont kno how the car startered before the problem but it use to work perfectly until your same problem happen to me i just connected a thick *** wire from the engine to a ground and havent had any problems yet
Old Mar 26, 2008 | 05:24 AM
ocelotz17's Avatar
im guessing you might have figured out the problem by now .. if not its the nuetral safety switch.. from all of what u said thats def ur problem .. when that goes it wont send power to the starter and alot of time when those go they give no warning .. but from all ur symptoms and what you've done that sounds like ur problem.. good luck
Old Mar 26, 2008 | 06:52 AM
jsant07's Avatar
Default Re: (ocelotz17)
its 5spd there is no neutral safety switch
