new battery. new alternator. still only 12v when car is running
Old Mar 2, 2008 | 01:23 PM
red civic standard's Avatar
Default new battery. new alternator. still only 12v when car is running
90 Civic DX with stock DPFI motor...198,000 miles.
Brand new battery. Brand new alternator.
Voltage tester shows 12v on battery whether the engine is running or not.
The white output wire from the alternator also only shows 12v when the car is running.
I feel the problem must be in the four wires in the green plug that goes into the alternator. So we tested those.
What color/Volts/Volts with key to run/Volts when running
Black/Yellow 0/12/11.75
White/Yellow 0/.01/.01
Yellow 0/4.6/4.6
White/Blue 0/12/11.38
Voltage at the battery jumps to 14 right when the car starts and then goes back down to 12.
There is continuity between battery and the output post on the alternator.
Help!!
Old Mar 2, 2008 | 05:40 PM
grog's Avatar
Default Re: new battery. new alternator. still only 12v when car is running (red civic standard)
I've seen alot of these threads lately and it usualy turns out to be the alternator, even when they test good in the store.
See if you can exchange yours for another one where you bought it.
Old Mar 3, 2008 | 02:34 AM
Default Re: new battery. new alternator. still only 12v when car is running (grog)
this is the third alternator that we have tried.
SpoonEk253
Jan 5, 2022 09:23 PM
Speed--Freak
15
Jan 5, 2022 05:22 AM
Corksil
12
Mar 1, 2018 03:52 PM
mongoliandonuts
Mar 14, 2004 06:20 PM
