what kind of gear oil on a manual transmission
Old Mar 2, 2008 | 10:27 AM
thiscivicuser's Avatar
Default what kind of gear oil on a manual transmission
what kind of gear oil do i use on a manual tranmission civic 97 at 120,000.
Old Mar 2, 2008 | 10:44 AM
jax97hx's Avatar
Default Re: what kind of gear oil on a manual transmission (thiscivicuser)
go to a honda dealer and buy 2 quarts of mtf = manual tanny fluid
Old Mar 2, 2008 | 10:58 AM
Default Re: what kind of gear oil on a manual transmission (jax97hx)
can't i just use the ones at pep boys or auto zone they have like 75-90w or 95 to 140w i just want to know wut kind of wegiht can i use.
Old Mar 2, 2008 | 11:12 AM
kieran84's Avatar
ive heard 10w40 engine oil is great for honda trans
Old Mar 2, 2008 | 11:25 AM
sicones's Avatar
Default Re: what kind of gear oil on a manual transmission (kieran84)
regular 10w30 motor oil or honda MTF, use gear oil if you want to replace the transmission
Old Mar 2, 2008 | 11:32 AM
dannycraq's Avatar
i use 10w30 motor oil, works great
Old Mar 2, 2008 | 12:02 PM
NOFX's Avatar
H-T White Ops
just stick to the manufacturer's recommendation (Honda MTF). It's not expensive and it's not like you're going to be buying it often.
Old Mar 2, 2008 | 12:03 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (NOFX)
Honda MTF is like 4 bucks a quart, 70w90 or wahtever at autozone is too thick
Old Mar 2, 2008 | 12:04 PM
Blzdeep's Avatar
Old Mar 2, 2008 | 12:23 PM
thedanny88's Avatar
Default Re: what kind of gear oil on a manual transmission (Blzdeep)
10w30
Old Mar 2, 2008 | 12:51 PM
Crx Jimmy's Avatar
Default Re: what kind of gear oil on a manual transmission (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">regular 10w30 motor oil or honda MTF, use gear oil if you want to replace the transmission</TD></TR></TABLE>
??^^ why would gear oil make the transmission break or go bad? I dont think you know what you are talking about. Almost every aftermarket LSD(ATS, Kaaz, Cusco, ect) requires you to use their own friction modified 80-90 gear oil. Most people that have these diffs run them hard on the race tracks and you dont see them blowing up trannys from using gear oil. WTF?
Old Mar 2, 2008 | 01:08 PM
thursday's Avatar
Default Re: what kind of gear oil on a manual transmission (Crx Jimmy)
taken DIRECTLY from a crx fsm
"Use only SAE 10w-30 or 10w-40 oil rated SE or SF grade"
i did read on a kaaz installation that you are supposed to use 80/90w gl-5 lsd oil, i think they are generalizing towards the rwd transmission applications that use this weight oil stock.
https://honda-tech.com/zerothread?id=1875353
dont use heavy weight oil in a honda transaxle (.)
Old Mar 2, 2008 | 01:43 PM
sicones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
??^^ why would gear oil make the transmission break or go bad? I dont think you know what you are talking about. Almost every aftermarket LSD(ATS, Kaaz, Cusco, ect) requires you to use their own friction modified 80-90 gear oil. Most people that have these diffs run them hard on the race tracks and you dont see them blowing up trannys from using gear oil. WTF?</TD></TR></TABLE>
I don't think YOU know what your talking about
READ!!
https://honda-tech.com/zerothread?id=1763113
Old Mar 2, 2008 | 07:16 PM
Crx Jimmy's Avatar
READ!!
https://honda-tech.com/zerothread?id=1763113</TD></TR></TABLE>
Yeah I did! they said they DO run gear oil in lsd tranny's mista bone even dsaid to run syncormesh which is a gear oil
Old Mar 2, 2008 | 07:28 PM
jax97hx's Avatar
THE FACT IS honda mtf is not that expensive and it is the BEST choice for a stock non lsd tranny so quit being difficult and go buy some.
Old Mar 3, 2008 | 04:10 AM
StorminMatt's Avatar
Yeah I did! they said they DO run gear oil in lsd tranny's mista bone even dsaid to run syncormesh which is a gear oil </TD></TR></TABLE>
Synchromesh may be gear oil in the sense that it is used in transmissions. But it is NOT the same thing as the GL-4/GL-5 high viscosity gear oils (ie 85W90, 85W140, etc) that are used on old-school transmissions. These oils are WAYYYY too thick for Honda transmissions (and MANY other newer manual transmissions), and will not be able to penetrate into tight spaces to lubricate MANY of the bearings. SO stay away from the thick stuff. Remember that Honda's original recommendation for these cars is 10W30 or 10W40 motor oil. There was no Honda MTF at the time. Of course, Honda MTF is a GREAT lubricant, as is synchromesh. Both of these oils are low viscosity gear oils. As for using 80W90 oil with an LSD, from what I have seen MANY of these higher end oils are actually quite a bit lighter than your typical GL-4/GL-5 85W90.
Old Mar 3, 2008 | 04:17 AM
cehcivic15's Avatar
Default Re: what kind of gear oil on a manual transmission (StorminMatt)
i like to run 10w40 with some lucas
Old Mar 3, 2008 | 08:45 PM
thursday's Avatar
i've actually ruined a vx tranny from running gear oil in it.
Crossbreeder
Sep 24, 2009 09:18 AM
9.3.S.I.L.U.D.E.
Transmission & Drivetrain
32
Jul 26, 2009 08:50 PM
gonshik007
Sep 22, 2008 05:42 PM
boosted94teggy
Oct 27, 2005 12:42 PM
ToFu-DeLiVeRy
May 24, 2004 05:36 PM
